عدم نمایش jquerydataTables
من کدهای زیر را نوشته ام
<!DOCTYPE html>
<html>
<head>
    <meta charset="utf-8" />
    <meta name="viewport" content="width=device-width, initial-scale=1.0">
    <title>@ViewBag.Title - My ASP.NET Application</title>
    @Styles.Render("~/Content/css")
    @Scripts.Render("~/bundles/modernizr")
</head>
<body>
    <div class="navbar navbar-inverse navbar-fixed-top">
        <div class="container">
            <div class="navbar-header">
                <button type="button" class="navbar-toggle" data-toggle="collapse" data-target=".navbar-collapse">
                    <span class="icon-bar"></span>
                </button>
                @Html.ActionLink("Application name", "Index", "Home", new { area = "" }, new { @class = "navbar-brand" })
            </div>
            <div class="navbar-collapse collapse">
                <ul class="nav navbar-nav">
                    <li>@Html.ActionLink("Home", "Index", "Home")</li>
                    <li>@Html.ActionLink("About", "About", "Home")</li>
                    <li>@Html.ActionLink("Contact", "Contact", "Home")</li>
                </ul>
            </div>
        </div>
    </div>
    <div class="container body-content">
        @RenderBody()
        <hr />
        <footer>
            <p>&copy; @DateTime.Now.Year - My ASP.NET Application</p>
        </footer>
    </div>
    @Scripts.Render("~/bundles/jquery")
    @Scripts.Render("~/bundles/bootstrap")
    @RenderSection("scripts", required: false)
</body>
</html>
و
@model IEnumerable<WebApplication26.Models.Form>
    ViewBag.Title = "Index";
    Layout = "~/Views/Shared/_Layout.cshtml";
<link href="~/Content/DataTables/css/jquery.dataTables.min.css" rel="stylesheet" />
<h2>Index</h2>
<p>
    @Html.ActionLink("Create New", "Create")
</p>
<table class="table" id="assets-data-table">
    <tr>
        <th>
            @Html.DisplayNameFor(model => model.Name)
        </th>
        <th>
            @Html.DisplayNameFor(model => model.FrmName)
        </th>
        <th></th>
    </tr>
    @foreach (var item in Model)
        <tr>
            <td>
                @Html.DisplayFor(modelItem => item.Name)
            </td>
            <td>
                @Html.DisplayFor(modelItem => item.FrmName)
            </td>
            <td>
                @Html.ActionLink("Edit", "Edit", new { id = item.Id }) |
                @Html.ActionLink("Details", "Details", new { id = item.Id }) |
                @Html.ActionLink("Delete", "Delete", new { id = item.Id })
            </td>
        </tr>
</table>
@section Scripts
    <script src="~/Scripts/DataTables/jquery.dataTables.min.js"></script>
    <script src="~/Scripts/DataTables/dataTables.bootstrap.min.js"></script>
    <script type="text/javascript">
        $(document).ready(function () {
            $('#assets-data-table').DataTable( {
                "paging"  :     true,
                "ordering":     true,
                "info"    :     true,
                "filter"  :     true,
                "order"   :     [[ 0, "desc" ]]
    </script>
وقتی کد
              "paging"  :     true,
              "ordering":     true,
              "info"    :     true,
              "filter"  :     true,
درج نکرده ام هیچ اروری وجود ندارد و البته jquerydataTables هم کار نمیکند
ولی وقتی کد بارا مینویسم
برنامه اجرا میشود ولی در Console ارور زیر رخ میدهد برای حل مشکل چکار باید کنم
<c#>
<!DOCTYPE html>
<html>
<head>
    <meta charset=utf-8 />
    <meta name=viewport content=width=device-width, initial-scale=1.0>
    @Styles.Render(~/Content/css)
    @Scripts.Render(~/bundles/modernizr)
</head>
<body>
    <div class=navbar navbar-inverse navbar-fixed-top>
        <div class=container>
            <div class=navbar-header>
                <button type=button class=navbar-toggle data-toggle=collapse data-target=.navbar-collapse>
                    <span class=icon-bar></span>
                </button>
                @Html.ActionLink(Application name, Index, Home, new { area =  }, new { @class = navbar-brand })
            </div>
            <div class=navbar-collapse collapse>
                <ul class=nav navbar-nav>
                    <li>@Html.ActionLink(Home, Index, Home)</li>
                    <li>@Html.ActionLink(About, About, Home)</li>
                    <li>@Html.ActionLink(Contact, Contact, Home)</li>
                </ul>
            </div>
        </div>
    </div>
    <div class=container body-content>
        @RenderBody()
        <hr />
        <footer>
        </footer>
    </div>
    @Scripts.Render(~/bundles/jquery)
    @Scripts.Render(~/bundles/bootstrap)
    @RenderSection(scripts, required: false)
</body>
</html>
<c#>
و
<c#>
    ViewBag.Title = Index;
    Layout = ~/Views/Shared/_Layout.cshtml;
<link href=~/Content/DataTables/css/jquery.dataTables.min.css rel=stylesheet />
<h2>Index</h2>
<p>
    @Html.ActionLink(Create New, Create)
</p>
<table class=table id=assets-data-table>
    <tr>
        <th>
        </th>
        <th>
        </th>
        <th></th>
    </tr>
        <tr>
            <td>
            </td>
            <td>
            </td>
            <td>
                @Html.ActionLink(Edit, Edit, new { id = item.Id }) |
                @Html.ActionLink(Details, Details, new { id = item.Id }) |
                @Html.ActionLink(Delete, Delete, new { id = item.Id })
            </td>
        </tr>
</table>
@section Scripts
    <script src=~/Scripts/DataTables/jquery.dataTables.min.js></script>
    <script src=~/Scripts/DataTables/dataTables.bootstrap.min.js></script>
    <script type=text/javascript>
                paging  :     true,
                ordering:     true,
                info    :     true,
                filter  :     true,
                order   :     [[ 0, desc ]]
    </script>
<c#>
وقتی کد
<js>
              paging  :     true,
              ordering:     true,
              info    :     true,
              filter  :     true,
<js>
||https://tosinso.com/files/get/3a998ff7-f6b6-4b37-b103-80711a97b0ac||
پرسیده شده در 1396/12/22 توسط
مشکل عدم استفاده از تگ های thead , tbody چون نه در خود سایتش ونه منابع دیگر این نکته ذکر نشده بودش
پاسخ در 1396/12/22 توسط
سلام به شما دوست عزیز
برای دیتاتیبل باید جدول به صورت کامل نوشته شود یعنی از تگ های thead , tbody هم باید استفاده کنید. برای حل این خطا تست کنید ببینید که برنامه به درستی به کتابخانه های اضافه شده دسترسی دارد یا خیر.
