مشکل گرافیک(پریمر).......فوری
چند روزه انگار گرافیکم مشکل پیدا کرده مثلا در obs studio دیسپلی کپچر رو باز نمیکنه(صفحه سیاه میاره) چند روش امتحان کردم درست نشد الآن هم پریمر ارور میده واسه گرافیک
پرسیده شده در 1399/03/25 توسط
گزینه اکسپرت هم داره اونو میزنم 2فایل txt میزاره
فایل txt اولSystemCompatibilityReport:
____________________________________________________________________________
System Components:
Operating System    Windows v.10.0.18363.1
 No conflicts to report.
Video    Intel(R) HD Graphics 4000 v.10.18.10.4358
1. The current version of your Intel display driver may cause performance and stability issues.  It is strongly recommended that you update to driver version 100.6286 or later.  Drivers are provided by Intel or your computer's manufacturer.
 URL: https://helpx.adobe.com/premiere-pro/kb/drivers-video-win-intel.html
Video    NVIDIA GeForce GT 720M v.23.21.13.8873
1. NVIDIA has identified a bug which causes random crashes in your Adobe application and has provided a fix in driver version 430.86. This driver update is strongly recommended.
 URL: https://helpx.adobe.com/premiere-pro/kb/drivers-video-win-nvidia.html
Audio    Intel(R) Display Audio v.6.16.0.3154
Audio    Realtek High Definition Audio v.6.0.1.7553
Network    Microsoft Hosted Network Virtual Adapter v.10.0.18362.1
Network    Microsoft Kernel Debug Network Adapter v.10.0.18362.1
Network    Microsoft Wi-Fi Direct Virtual Adapter v.10.0.18362.1
Network    Microsoft Wi-Fi Direct Virtual Adapter #2 v.10.0.18362.1
Network    Qualcomm Atheros AR9485WB-EG Wireless Network Adapter v.3.0.2.201
Network    Realtek PCIe GBE Family Controller v.8.23.1126.2013
Network    TAP-Windows Adapter V9 v.9.24.2.601
Network    WAN Miniport (IKEv2) v.10.0.18362.1
Network    WAN Miniport (IP) v.10.0.18362.1
Network    WAN Miniport (IPv6) v.10.0.18362.1
Network    WAN Miniport (L2TP) v.10.0.18362.1
Network    WAN Miniport (Network Monitor) v.10.0.18362.1
Network    WAN Miniport (PPPOE) v.10.0.18362.1
Network    WAN Miniport (PPTP) v.10.0.18362.1
Network    WAN Miniport (SSTP) v.10.0.18362.1
Analyzing project: Untitled.prproj
 Details in file "SystemCompatibilityReport.ProjectAnalysis.txt"
    No errors were found.
GPU Sniffer Log:
GPUSniffer launching with test mask 62
GPU Sniffer Output:
GPUSniffer testing 62
Initializing GPU Tech:
 Try CUDA: 1
 Try OpenCL: 1
 Try Metal: 0
 Try Vulkan: 0
 KernelLoadAction: 0
 UseOpenGLContext: 0000000000000000
 UseDeviceContext: 0000000000000000
 UseD3D11Context: 0000000000000000
CUDA system device count: 1
 Found CUDA device index: 0 Name: GeForce GT 720M
     No capability restrictions detected - adding device to list
OpenCL system device count: 2
 Found OpenCL device Name: GeForce GT 720M supportsSSG: 0
 Skipping nVidia OpenCL device
 Found OpenCL device Name: Intel(R) HD Graphics 4000 supportsSSG: 0
Finished gpu initialization in 0 ms
--- OpenGL Info ---
Vendor: NVIDIA Corporation
Renderer: GeForce GT 720M/PCIe/SSE2
OpenGL Version: 2.1.2 NVIDIA 388.73 23.21.13.8873
GLSL Version: 1.20 NVIDIA via Cg compiler
Monitors: 1
Monitor 0 properties -
   Size: (0, 0, 1366, 768)
   Max texture size: 16384
   Supports non-power of two: 1
   Shaders 444: 1
   Shaders 422: 1
   Shaders 420: 1
--- GPU Computation Info ---
Found 2 devices supporting GPU computation.
CUDA Device 0 -
   Vendor: NVIDIA
 Integrated: 0
   Capability: 2.1
   Driver: 9.1
   Total Video Memory: 2048MB
   * Not chosen because of old driver.
OpenCL Device 1 -
   Vendor: Intel
 Integrated: 1
   Capability: 1.2
   Driver: 1.2
   Total Video Memory: 1400MB
   * Not chosen because of insufficient compute unit count.
GPU Sniffer result: 14
In Process GPU Initialization Log:
 Try CUDA: 0
 Try OpenCL: 0
 Try Metal: 0
 Try Vulkan: 0
 KernelLoadAction: 2
 UseD3D11Context: 00000000257747A8
Finished gpu initialization in 1.10971e+06 ms
    Debug database settings:
        All settings default value
    Notable Preferences:
        Enable hardware decoding: 1
        Last used renderer name: Software
        Enable display color management:  Not set (will use default value)
        Enable Extended Dynamic Range Monitoring:  Not set (will use default value)
        Write clip markers to XMP:  Not set (will use default value)
        Enable growing files:  Not set (will use default value)
        Missing font replacement:  Not set (will use default value)
فایل txt دومSystemCompatibilityReport.ProjectAnalysis:
[PROJECT] Analyzing Project: Untitled.prproj
.  GUID: 2d483c04-1f44-456e-af6e-ac1f442c00c0
پاسخ در 1399/03/25 توسط
درود
نرم افزار Driver Display Unistaller را نصب کنید و اقدام به حذف درایورهای قدیمی و نصب درایور جدید کنید.
به امید خدا مشکلتون حل شود.
پاسخ در 1399/03/26 توسط
به امید خدا حل بشه.
معمولا با نصب درایور جدید از وب سایت سازنده یا سایت معتبری مثل Guru3d.com می تونید درایورهای جدید دریافت کنید.
