مشکل در راه اندازی xl2tpd.service در centos 7
بپرسید
  • 910****28 910****28
  • 41 ماه قبل
  • 41 ماه قبل
  • 232 نمایش
با سلام و عرض خسته نباشید
قصد دارم از طرق کانکشن l2tp به سرور لینوکس وصل بشم ولی در مرحله پیکربندی سرویس xl2tpd.service راه اندازی نمیشه
لطفا راهنمایی کنید.
Dec 09 09:52:02  xl2tpd[3162]: xl2tpd[3162]: parse_config: line 1: data 'global]' occurs with no context
Dec 09 09:52:02  xl2tpd[3162]: xl2tpd[3162]: init: Unable to load config file
Dec 09 09:52:02  systemd[1]: xl2tpd.service: main process exited, code=exited, status=1/FAILURE
Dec 09 09:52:02  systemd[1]: Unit xl2tpd.service entered failed state.
Dec 09 09:52:02  systemd[1]: xl2tpd.service failed.
Dec 09 09:52:02  systemd[1]: xl2tpd.service holdoff time over, scheduling restart.
Dec 09 09:52:02  systemd[1]: Stopped Level 2 Tunnel Protocol Daemon (L2TP).
-- Subject: Unit xl2tpd.service has finished shutting down
-- Defined-By: systemd
-- Support: http://lists.freedesktop.org/mailman/listinfo/systemd-devel
-- Unit xl2tpd.service has finished shutting down.
Dec 09 09:52:02  systemd[1]: start request repeated too quickly for xl2tpd.service
Dec 09 09:52:02  systemd[1]: Failed to start Level 2 Tunnel Protocol Daemon (L2TP).
-- Subject: Unit xl2tpd.service has failed
-- Unit xl2tpd.service has failed.
-- The result is failed.
Dec 09 09:52:35  unix_chkpwd[3172]: password check failed for user (root)
Dec 09 09:52:35  sshd[3170]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=141.98.80.177  user=root
Dec 09 09:52:35  sshd[3170]: pam_succeed_if(sshd:auth): requirement "uid >= 1000" not met by user "root"
Dec 09 09:52:37  sshd[3170]: Failed password for root from 141.98.80.177 port 49134 ssh2
Dec 09 09:52:37  sshd[3170]: Received disconnect from 141.98.80.177 port 49134:11: Client disconnecting normally [preauth]
Dec 09 09:52:37  sshd[3170]: Disconnected from 141.98.80.177 port 49134 [preauth]
Dec 09 09:53:40  sshd[3173]: Did not receive identification string from 83.97.20.29 port 3437
پاسخ ها به این سوال
پاسخ ها به این سوال
{{ digitTrunc(post.likes) }}
{{ err }}
