خطای این برنامه چیست ؟
from tkinter import *
import sqlite3
root = Tk()
root.title("Python: Simple Login Application")
width = 400
height = 280
screen_width = root.winfo_screenwidth()
screen_height = root.winfo_screenheight()
x = (screen_width/2) - (width/2)
y = (screen_height/2) - (height/2)
root.geometry("%dx%d+%d+%d" % (width, height, x, y))
root.resizable(0, 0)
#==============================METHODS========================================
def Database():
    global conn, cursor
    conn = sqlite3.connect("pythontut.db")
    cursor = conn.cursor()
    cursor.execute("CREATE TABLE IF NOT EXISTS `member` (mem_id INTEGER NOT NULL PRIMARY KEY  AUTOINCREMENT, username TEXT, password TEXT)")
    cursor.execute("SELECT * FROM `member` WHERE `username` = 'admin' AND `password` = 'admin'")
    if cursor.fetchone() is None:
        cursor.execute("INSERT INTO `member` (username, password) VALUES('admin', 'admin')")
        conn.commit()
def Login(event=None):
    global cursor
    Database()
    if USERNAME.get() == "" or PASSWORD.get() == "":
        label.config(text="Please complete the required field!", fg="red")
    else:
        cursor.execute("SELECT * FROM `member` WHERE `username` = ? AND `password` = ?", (USERNAME.get(), PASSWORD.get()))
        if cursor.fetchone() is not None:
            HomeWindow()
            USERNAME.set("")
            PASSWORD.set("")
            label.config(text="")
        else:
            label.config(text="Invalid username or password", fg="red")
            USERNAME.set("")
            PASSWORD.set("")
    cursor.close()
    conn.close()
def HomeWindow():
    global Home
    root.withdraw()
    Home = Toplevel()
    Home.title("Python: Simple Login Application")
    width = 600
    height = 500
    Home.geometry("%dx%d+%d+%d" % (width, height, x, y))
    Home.resizable(0, 0)
    lbl_home = Label(Home, text="Successfully Login!", font=('times new roman', 20)).pack()
    btn_back = Button(Home, text='Back', command=Back).pack(pady=20, fill=X)
def Back():
    Home.destroy()
    root.deiconify()
#==============================VARIABLES======================================
USERNAME = StringVar()
PASSWORD = StringVar()
#==============================FRAMES=========================================
Top = Frame(root, bd=2,  relief=RIDGE)
Top.pack(side=TOP, fill=X)
Form = Frame(root, height=200)
Form.pack(side=TOP, pady=20)
#==============================LABELS=========================================
lbl_title = Label(Top, text = "Python: Simple Login Application", font=('arial', 15))
lbl_title.pack(fill=X)
lbl_username = Label(Form, text = "Username:", font=('arial', 14), bd=15)
پرسیده شده در 1402/04/14 توسط
سلام درود دوست عزیزخطایی که در برنامه وجود دارد این است که تابع `Label` در انتهای کد نیم‌کامل است و بدون پایانی از آن استفاده می‌شود. برای رفع این خطا، کافی است در خط بعدی این تابع را پایان دهید. به شکل زیر:
lbl_username = Label(Form, text="Username:", font=('arial', 14), bd=15)
پس از این تغییر، می‌توانید به برنامه‌ی خود ادامه دهید و به اجرای آن بپردازید
موفق باشید
پاسخ در 1402/04/18 توسط
سلام. لطف کنید با جزئیات بیشتر سوالتون رو مطرح کنین . مشخص کنید ، تو چه خطی ، چه خطایی دریافت میکنید.
پاسخ در 1402/04/15 توسط
