مشکل با برنامه نویسی اندروید در ویژوال استودیو 2015
زامارین و پیش نیازهای آن و ویژوال استودیو 2015 را نصب کردم. کرک هم شده حالا ولی خروجی Xamarin Diagnostics به شکل زیر هست. تعداد دستگاه های پیدا شده رو میگه صفر هست.
من تازه در شروع کار برنامه نویسی اندروید هستم لطفا راهنمایی کنید چی کار کنم
[W:]:                     Adb connection refused
[I:]:                     Starting Adb server (adb start-server)
[I:]:                     Adb start-server operation completed
[D:]:                     TrackDeviceTask got:
[I:]:                     Got new device list from adb with 0 devices
[D:]:                     avd watcher: got device list from avd with 0 devices
کاملش رو هم اینجا میزارم
[I:sdk]:                  Looking for Android SDK..
[I:sdk]:                    Key HKCU\SOFTWARE\Novell\Mono for Android\AndroidSdkDirectory not found.
[I:sdk]:                    Key HKLM\SOFTWARE\Novell\Mono for Android\AndroidSdkDirectory found:
   Path does not contain adb.exe in \platform-tools (C:\android-sdk-windows).
[I:sdk]:                    Key HKCU\SOFTWARE\Xamarin\MonoAndroid\PrivateAndroidSdkPath not found.
[I:sdk]:                    Key HKCU\SOFTWARE\Android SDK Tools\Path not found.
[I:sdk]:                    Key HKLM\SOFTWARE\Android SDK Tools\Path found:
   Path contains adb.exe in \platform-tools (C:\Program Files\Android\android-sdk).
[I:sdk]:                  Looking for Android NDK..
[I:sdk]:                    Key HKCU\SOFTWARE\Novell\Mono for Android\AndroidNdkDirectory found:
   Path contains ndk-stack.exe in \. (C:\Program Files\Android\android-sdk\android-ndk-r10).
[I:sdk]:                    Key HKLM\SOFTWARE\Novell\Mono for Android\AndroidNdkDirectory not found.
[I:sdk]:                    Key HKCU\SOFTWARE\Novell\Mono for Android\JavaSdkDirectory not found.
[I:sdk]:                    Key HKLM\SOFTWARE\Novell\Mono for Android\JavaSdkDirectory not found.
[I:sdk]:                  Looking for Java 6 SDK..
[I:sdk]:                    Key HKLM\SOFTWARE\JavaSoft\Java Development Kit\CurrentVersion found.
[I:sdk]:                    Key HKLM\SOFTWARE\JavaSoft\Java Development Kit\1.6\JavaHome not found.
[I:sdk]:                    Key HKLM\SOFTWARE\JavaSoft\Java Development Kit\1.7\JavaHome found:
   Path contains jarsigner.exe in \bin (C:\Program Files\Java\jdk1.7.0_51).
[I:Unknown]:              Found Android SDK. API levels: 20, 21, 23
[I:Unknown]:              Found Xamarin.Android 6.0.2
[I:]:                     Tracking android devices started
[D:]:                     Tracking avd started
[D:]:                     avd watcher *.ini path: 'C:\Users\Mehran\.android\avd'
[D:]:                     avd watcher android path: 'C:\PROGRA~1\Android\ANDROI~1\tools\android.bat'
پرسیده شده در 1395/09/17 توسط
من شبیه ساز Xamarin Android Player رو سیستمم نصب کردم
اگه دقیقتر بهم بگین چی کار کنم ممنون میشم. تازه دارم یاد میگیرم. منابع هم براش خیلی کمه
پاسخ در 1395/09/20 توسط
اگر لطف کنید در مورد این چیزهایی که گفتید یه توضیحی بدید ممنون میشم و اینکه چطور این بخشها رو تنظیم کنم
چون تا حالا مطلبی در موردشون ندیدم
پاسخ در 1395/09/19 توسط
شبیه ساز چیزی است که برنامه اندرویدی را بر روی آن تست می کنید. مانند شبیه ساز خود گوگل یا گوشی موبایل فیزیکی و یا genymotion که یکی از اینها باید در حال اجرا بوده و برنامه بتواند با آن ارتباط برقرار کند.
برای این که ماشین های مجازی و یا شبیه ساز ها بر روی کامپیوتر شما به درستی اجرا شوند و سرعت قابل قبول را داشته باشند باید در قسمت بایوس کامپیوتر خود مجازی سازی را از cpu خود فعال کنید که intel-vt نام دارد.
Intel Hardware Accelerated Execution Manager (HAXM) برای بالا بردن سرعت شبیه ساز است که هنگام نصب sdk آن نیز باید نصب شود.
Xamarin Android Player مشکل داره
بهتره که genymotion رو نصب کنید توی این ویدیو روش نصب genymotion گفته شده است.
پاسخ در 1395/09/21 توسط
سلام آیاقبل از اجرای برنامه نوشته شده برنامه شبیه ساز شما در حال اجرا است؟
آیا در قسمت bios بخش virtualization را راه اندازی کرده اید؟
آیا Intel Hardware Accelerated Execution Manager (HAXM) را هنگام نصب زامارین انجام داده اید؟
پاسخ در 1395/09/18 توسط
