خطای mysqli_fetch_array()
با سلام من توی کدم با این خطا مواجهه شدم هر کاری کردم درست نشد دوستان راهنمایی کنید لطفا
خطا :
Warning: mysqli_fetch_array() expects parameter 1 to be mysqli_result, boolean given in /home/SITE/public_html/site/index.php on line 12
سورس کد :
<?php
session_start();
require_once('config.php');
require_once('telegram.php');
$refID = $_GET['ref'];
$proID = $_GET['pro'];
function getFromDB($query,$target){
$con = mysqli_connect("localhost",CFG_DB_USER,CFG_DB_PASS,CFG_DB_DB);
$con->set_charset("utf8");
$result = mysqli_query($con,$query);
$row = mysqli_fetch_array($result, MYSQLI_BOTH);
return $row[$target];
$proQuery = "SELECT * FROM product WHERE id = $proID";
$proAmount = getFromDB($proQuery,"amount");
$MerchantID = "B3F550AF24BD8F72B8FC"; //Required
$Amount = $proAmount; //Amount will be based on Toman - Required
$Description = 'خرید محصول شماره #'.$proID.' از فروشگاه'; // Required
$Email = $refID; // Optional
$CallbackURL = 'http://maxbot.in/bot/pay/verify.php'; // Required
$_SESSION["proAmount"] = $proAmount;
$_SESSION["proRef"] = $refID;
$_SESSION["proID"] = $proID;
$url = $_SERVER['REQUEST_URI']; //returns the current URL
$parts = explode('/',$url);
$callback = $_SERVER['SERVER_NAME'];
for ($i = 0; $i < count($parts) - 1; $i++) {
$callback .= $parts[$i] . "/";
$callback .= "verify.php";
if(1 == 1){
$url = 'http://panel.sabzpay.com/api/create/'; // don't change
$description = $Description;
$callback .= "?amount=".$Amount;
$fields = array(
'amount' => urlencode($Amount),
'pin' => urlencode($MerchantID),
'description' => urlencode($description),
'callback' => urlencode($callback),
$fields_string = "";
foreach($fields as $key=>$value) { $fields_string .= $key.'='.$value.'&'; }
rtrim($fields_string, '&');
$ch = curl_init();
curl_setopt($ch,CURLOPT_URL, $url);
curl_setopt($ch,CURLOPT_POST, count($fields));
curl_setopt($ch,CURLOPT_POSTFIELDS, $fields_string);
curl_setopt($ch, CURLOPT_RETURNTRANSFER, true);
$result = curl_exec($ch);
curl_close($ch);
if(is_numeric($result)){
echo '
<span style="color:red">ارور : '.$result.'</span>';
} else {
echo $result;
header('Location: http://panel.sabzpay.com/startpay/'.$result);
نمونه ای که بالا نوشته بودم مثال بودش اما دقیق تر بخوام بنویسم به صورت زیر می باشد. کافیه بعد از
این عبارت باشه
if (!$result) {
printf("Error: %s\n", mysqli_error($con));
exit();
سلام دوست گرامی این پیامی که sql به شما نشون میده ناشی از خطا داشتن در کوئری و برگشت مقدار false می باشد. بعداز عبارت
mysqli_query()
این دستور رو قرار بده ببینی داستان از چه قرار هست
if (!$check1_res) {
exit();
راستی بررسی کنید ببینید databse رو براش درست انتخاب و معرفی کردی بعضی موقع ها به خاطر تعریف نشدن درست پایگاه داده این خطا ممکنه رخ بده.
کد را توی کدوم قسمت قرار بدم؟
