فوری - برنامه aircraft contorol
سلام کسی می تونه بگه مشکل این کد کجاست؟
import java.io.*;
package airtraffic;
public class airtraffic {
public static void main(String[] args) {
/ TODO code application logic here
IAirTrafficControl tower = new Tower();
Aircraft flight1 = new Airbus("AC159", tower);
Aircraft flight2 = new Boeing("WS203", tower);
Aircraft flight3 = new Fokker("AC602", tower);
flight1.Altitude += 1000;
/base class for all colleagues called AirTrafiic
public abstract class AirTrafficControl
private final IAirTrafficControl _atc;
private int _currentAltitude;
protected AirTrafficControl(string callSign, IAirTrafficControl atc)
_atc = atc;
CallSign = callSign;
_atc. RegisterATCUnderGuidance(this);
public abstract int Ceiling { get; }
public string CallSign { get; private set; }
public int Altitude
get { return _currentAltitude; }
set
_currentAltitude = value;
_atc.ReceiveATCLocation(this);
public void Climb(int heightToClimb)
Altitude += heightToClimb;
public bool Equals(object obj)
if (obj.GetType() != this.GetType()) return false;
var incoming = (AirTrafficControl)obj;
return this.CallSign.Equals(incoming.CallSign);
public int GetHashCode()
return CallSign.GetHashCode();
public void WarnOfAirspaceIntrusionBy(AirTrafficControl reportingAircraft)
/do something in response to the warning
/******* Interface *******
public interface IAirTrafficControl
void ReceiveATCLocation(AirTrafficControl location);
void RegisterATCUnderGuidance(AirTrafficControl aircraft);
/ concrete types of aircraft or AirTrafficControl
public class Boeing extends AirTrafficControl
public Boeing(string callSign, IAirTrafficControl atc)
throws {
super(callSign, atc);
public int Ceiling
get { return 33000; }
public class Fokker extends AirTrafficControl
public Fokker(string callSign, IAirTrafficControl atc)
throws {
public int Ceiling
get { return 40000; }
public class Airbus extends AirTrafficControl
public Airbus(string callSign, IAirTrafficControl atc)
throws {
public int Ceiling
public class Tower implements IAirTrafficControl
private final IList[AirTrafficControl] _aircraftUnderGuidance = new List[AirTrafficControl]();
public void ReceiveAircraftLocation(AirTrafficControl reportingAircraft)
foreach (AirTrafficControl currentAircraftUnderGuidance in _aircraftUnderGuidance Where(x => x != reportingAircraft))
if (Math.abs(currentAircraftUnderGuidance.Altitude - reportingAircraft.Altitude) < 1000)
reportingAircraft.Climb(1000);
/communicate to the class
currentAircraftUnderGuidance.WarnOfAirspaceIntrusionBy(reportingAircraft);
public void RegisterATCUnderGuidance(AirTrafficControl aircraft)
if (!_RegisterATCUnderGuidance.Contains(aircraft))
_RegisterATCUnderGuidance.Add(aircraft);
}/end class AirTraffi
سلام به شما دوست عزیز
کدی که نوشتید با سینتکس های جاوا تفاوت داره و به خاطر همین این کد خطاهای زیادی داره. دقت داشته باشید که جاوا با سی شارپ تفاوت های زیادی داره. همچنین شما از کلاس Aircraft سه تا شی ساختید که اصلا کلاسی با این نام تعریف نکرده اید.
