استفاده از پروسیجر sql در گزارش استیمول
باسلام خدمت دوستان.
من در sql این پروسیجر رو نوشتم:
ALTER proc [dbo].[s_repgeneralfactorlist]
@fromdate nvarchar(10),
@todate nvarchar(10),
@accode int
as
(select factor.creatdate,
       case factor.typefactor when 1 then N'خرید' when 2 then N'فروش' when 3 then N'مرجوعی خرید' when 4 then N'مرجوعی فروش'end,
       factor.factornumber,
       factor.debtor,
       factor.creditor,
       factor.accountbalance
       from factor
       where factor.creatdate between @fromdate and @todate and factor.accountcode=@accode
       union select factordetail.goodsname,
       case factordetail.typefactor when 1 then N'خرید' when 2 then N'فروش' when 3 then N'مرجوعی خرید' when 4 then N'مرجوعی فروش'end,
       factordetail.number,
       factordetail.productcode,
       factordetail.saleprice,
       factordetail.total
       from factor inner join factordetail on factor.factornumber=factordetail.factornumber and factor.accountcode=@accode)
union select tblwpcash.creatdate,
             tblwpcash.status,
             tblwpcash.getcode,
             tblwpcash.debtor,
             tblwpcash.creditor,
             tblwpcash.accountbalance
             from tblwpcash where tblwpcash.creatdate between @fromdate and @todate and tblwpcash.accountcode=@accode and tblwpcash.getcode=5 and tblwpcash.status=N'دریافت نقدی'
             tblwpcash.status,
             tblwpcash.paycode,
             tblwpcash.debtor,
             tblwpcash.creditor,
             from tblwpcash where tblwpcash.creatdate between @fromdate and @todate and tblwpcash.accountcode=@accode and tblwpcash.paycode=6 and tblwpcash.status=N'پرداخت نقدی'
             case tblwpcash.status when N'پرداخت انتقالی حساب معین' then N'پرداخت انتقالی' end,
             tblwpcash.paycode,
             tblwpcash.debtor,
             tblwpcash.creditor,
             from tblwpcash where tblwpcash.creatdate between @fromdate and @todate and tblwpcash.accountcode=@accode and tblwpcash.paycode=6 and tblwpcash.status=N'پرداخت انتقالی حساب معین'
             case tblwpcash.status when N'پرداخت انتقالی حساب معین' then N'دریافت انتقالی' end,
             tblwpcash.getcode,
             tblwpcash.debtor,
             tblwpcash.creditor,
             from tblwpcash where tblwpcash.creatdate between @fromdate and @todate and tblwpcash.accountcodet=@accode and tblwpcash.getcode=5 and tblwpcash.status=N'پرداخت انتقالی حساب معین'
union select tblcheckpay.creatdate,
             tblcheckpay.checkstatus,
             tblcheckpay.paynum,
             tblcheckpay.debtor,
             tblcheckpay.creditor,
             tblcheckpay.accountbalance
             from tblcheckpay where tblcheckpay.creatdate between @fromdate and @todate and tblcheckpay.accountcode=@accode and tblcheckpay.paynum=8
             tblcheckpay.paychback,
             tblcheckpay.debtor,
             from tblcheckpay where tblcheckpay.creatdate between @fromdate and @todate and tblcheckpay.accountcode=@accode and tblcheckpay.paychback=10
union (select tblcheckpay.creatdate,
       tblcheckpay.paynum,
       tblcheckpay.debtor,
       from tblcheckpay
       where tblcheckpay.creatdate between @fromdate and @todate and (tblcheckpay.accountcode=@accode and tblcheckpay.paynum=8)
union select tblcheckreceipt.creatdate,
       case tblcheckreceipt.checkstatus when N'خرج شده' then N'چک پرداختی' end as 'وضعیت',
       tblcheckreceipt.chspent,
       tblcheckreceipt.debtor,
       tblcheckreceipt.creditor,
       tblcheckreceipt.accountbalance
       from tblcheckreceipt
       where tblcheckreceipt.creatdate between @fromdate and @todate and (tblcheckreceipt.accountcoder=@accode and tblcheckreceipt.chspent=11))
             tblcheckreceipt.checkstatus,
             tblcheckreceipt.getnum,
from tblcheckreceipt where tblcheckreceipt.creatdate between @fromdate and @todate and tblcheckreceipt.accountcode=@accode and tblcheckreceipt.getnum=7
             tblcheckreceipt.getchback,
from tblcheckreceipt where tblcheckreceipt.creatdate between @fromdate and @todate and tblcheckreceipt.accountcode=@accode and tblcheckreceipt.getchback=9
و در اجرا این رکوردهارو برمیگردونه که درسته:
باسلام خدمت دوستان.
<c#>
@accode int
as
       factor.debtor,
       factor.creditor,
       from factor
       factordetail.total
             tblwpcash.status,
             tblwpcash.getcode,
             tblwpcash.debtor,
             tblwpcash.creditor,
             tblwpcash.status,
             tblwpcash.paycode,
             tblwpcash.debtor,
             tblwpcash.creditor,
             tblwpcash.paycode,
             tblwpcash.debtor,
             tblwpcash.creditor,
             tblwpcash.getcode,
             tblwpcash.debtor,
             tblwpcash.creditor,
             tblcheckpay.paynum,
             tblcheckpay.debtor,
             tblcheckpay.debtor,
       tblcheckpay.paynum,
       tblcheckpay.debtor,
       from tblcheckpay
<c#>
||https://tosinso.com/files/get/57dd9e60-afa3-4bca-8ad3-cdc865991164||
حالا اگه بخوام تو استیمول کانکشن جدید درست کنم و این پروسیجر رو بعنوان datasource انتخاب کنم باید همه فیلدهایی که تو select های پروسیجر نوشتم رو بعنوان ورودی دیتاسورس تعریف کنم؟ خیلی از فیلدها تکراریه، تو استیمول خطا نداره؟
پرسیده شده در 1396/11/05 توسط
سلام، وقت بخیر. مهم فیلدهایی هست که تو خروجی SP تولید میشن و قراره داخل گزارش نمایش داده بشه.
پاسخ در 1396/11/05 توسط
سلام مجدد. من چون از چندتا جدول اطلاعات رو دارم نشون میدم و چندتا فیلدش تکراریه، تو استیمول که متغیرهارو تعریف کردم، خطا داشت...
پاسخ در 1396/11/07 توسط
