رمز شدن تمامی فایل های کامپیوتر
متوجه شدم که به پسوند تمامی فایلهای یکی از کامپیوترهای درون شبکه Workgroup که به اینترنت متصل است .abc اضافه شده
و همچنین یک فایل متنی در کنار فایلها است که می گوید فایلهای شما Encrypt شده است که متن زیر گویا است:
What happened to your files ?
All of your files were protected by a strong encryption with RSA-2048.
More information about the encryption keys using RSA-2048 can be found here: http://en.wikipedia.org/wiki/RSA_(cryptosystem)
What does this mean ?
This means that the structure and data within your files have been irrevocably changed, you will not be able to work with them, read them or see them,
it is the same thing as losing them forever, but with our help, you can restore them.
How did this happen ?
Especially for you, on our server was generated the secret key pair RSA-2048 - public and private.
All your files were encrypted with the public key, which has been transferred to your computer via the Internet.
Decrypting of your files is only possible with the help of the private key and decrypt program, which is on our secret server.
What do I do ?
Alas, if you do not take the necessary measures for the specified time then the conditions for obtaining the private key will be changed.
If you really value your data, then we suggest you do not waste valuable time searching for other solutions because they do not exist.
For more specific instructions, please visit your personal home page, there are a few different addresses pointing to your page below:
1. http://rtldkdh6.kghw88gh3eu.net/D225A7F595CCBDCD
2. http://jsdf2wevw2.wrt23wqw34.net/D225A7F595CCBDCD
3. https://7vhbukzxypxh3xfy.onion.to/D225A7F595CCBDCD
If for some reasons the addresses are not available, follow these steps:
1. Download and install tor-browser: http://www.torproject.org/projects/torbrowser.html.en
2. After a successful installation, run the browser and wait for initialization.
3. Type in the address bar: 7vhbukzxypxh3xfy.onion/D225A7F595CCBDCD
4. Follow the instructions on the site.
IMPORTANT INFORMATION:
Your personal pages:
Your personal page (using TOR): 7vhbukzxypxh3xfy.onion/D225A7F595CCBDCD
Your personal identification number (if you open the site (or TOR 's) directly): D225A7F595CCBDCD
راهنمایی بفرمایید
پرسیده شده در 1394/06/23 توسط
سیستم از شبکه جداست.
سیستم ریستور رو آزمایش نکردم تا ابتدا مشورت بگیرم
موفق باشید
پاسخ در 1394/06/28 توسط
باج افزار!!!
یادتون هست بعد از نصب چه برنامه ای و یا دانلود چه فایلی اینجوری شد سیستم؟
پاسخ در 1394/06/24 توسط
اصلا امکان نداره خود به خود این اتفاق بیفته!!! صد در صد از یه راهی این باج افزار وارد سیستم شده... system restore رو امتحان کردید؟
حقیقتا این نوع بدافزار خیلی قویه و تقریبا راه حلی نداره ولی تا وقتیکه میتونید سیستم رو خاموش نگه دارید و حتما از شبکه جدا باشه... تا بتونید راه حل ها رو امتحان کنید...
متاسفانه اون لینک کمکی نکرد
هیچ برنامه خاصی نبوده یک روز صبح که سیستم روشن شده این اتفاق افتاده
موفق باشید
