مشکل در Exchange Administrative Center
سروان گرامی-باسلام ، لطفا راهنمائی بفرمائید. خطا بهنگام اجرای Exchange Administrative Center
Server Error in '/ecp' Application.
Active Directory server is not available. Error message: Active directory response: The LDAP server is unavailable.
Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.
Exception Details: System.ServiceModel.FaultException`1[[Microsoft.Exchange.Data.Directory.TopologyDiscovery.TopologyServiceFault, Microsoft.Exchange.Data.Directory, Version=15.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35]]: Active Directory server is not available. Error message: Active directory response: The LDAP server is unavailable.
Source Error:
An unhandled exception was generated during the execution of the current web request. Information regarding the origin and location of the exception can be identified using the exception stack trace below.
Stack Trace:
[FaultException`1: Active Directory server is not available. Error message: Active directory response: The LDAP server is unavailable.]
System.Runtime.Remoting.Proxies.RealProxy.HandleReturnMessage(IMessage reqMsg, IMessage retMsg) +14483202
System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(MessageData& msgData, Int32 type) +622
Microsoft.Exchange.Data.Directory.TopologyDiscovery.ITopologyClient.GetServersForRole(String partitionFqdn, List`1 currentlyUsedServers, ADServerRole role, Int32 serversRequested) +0
Microsoft.Exchange.Data.Directory.<>c__DisplayClass10.<InternalServiceProviderGetServersForRole>b__f(IPooledServiceProxy`1 proxy) +145
Microsoft.Exchange.Net.ServiceProxyPool`1.TryCallServiceWithRetry(Action`1 action, String debugMessage, WCFConnectionStateTuple proxyToUse, Int32 numberOfRetries, Boolean doNotReturnProxyOnSuccess, Exception& exception) +274
[ADTransientException: The call to Microsoft Exchange Active Directory Topology service on server 'TopologyClientTcpEndpoint (localhost)' returned an error. Error details Active Directory server is not available. Error message: Active directory response: The LDAP server is unavailable..]
Microsoft.Exchange.Data.Directory.ServiceTopologyProvider.GetConfigDCInfo(String partitionFqdn, Boolean throwOnFailure) +506
Microsoft.Exchange.Data.Directory.TopologyProvider.PopulateConfigNamingContexts(String partitionFqdn) +88
Microsoft.Exchange.Data.Directory.TopologyProvider.GetConfigurationNamingContext(String partitionFqdn) +86
Microsoft.Exchange.Data.Directory.ADSession.GetConfigurationNamingContext(String partitionFqdn) +243
Microsoft.Exchange.Data.Directory.ADDataSession.GetNamingContext(ADNamingContext adNamingContext) +601
Microsoft.Exchange.Data.Directory.ADDataSession.GetConnection(String preferredServer, Boolean isWriteOperation, String optionalBaseDN, ADObjectId& rootId, ADScope scope) +686
Microsoft.Exchange.Data.Directory.ADDataSession.GetReadConnection(String preferredServer, String optionalBaseDN, ADObjectId& rootId, ADRawEntry scopeDeteriminingObject, DualSearchMode dualSearchMode) +202
Microsoft.Exchange.Data.Directory.ADDataSession.InternalFind(ADObjectId rootId, String optionalBaseDN, ADObjectId readId, QueryScope scope, QueryFilter filter, SortBy sortBy, Int32 maxResults, IEnumerable`1 properties, Boolean includeDeletedObjects) +3632
Microsoft.Exchange.Data.Directory.SystemConfiguration.ADTopologyConfigurationSession.FindServerByFqdn(String serverFqdn) +184
Microsoft.Exchange.Data.Directory.SystemConfiguration.Server.GetLocalServerClientAccessArray() +129
Microsoft.Exchange.HttpProxy.PerfCounters.UpdateHttpProxyPerArrayCounters() +12
Microsoft.Exchange.HttpProxy.ProxyApplication.Application_Start(Object sender, EventArgs e) +366
[HttpException (0x80004005): The call to Microsoft Exchange Active Directory Topology service on server 'TopologyClientTcpEndpoint (localhost)' returned an error. Error details Active Directory server is not available. Error message: Active directory response: The LDAP server is unavailable..]
System.Web.HttpApplicationFactory.EnsureAppStartCalledForIntegratedMode(HttpContext context, HttpApplication app) +12584905
System.Web.HttpApplication.RegisterEventSubscriptionsWithIIS(IntPtr appContext, HttpContext context, MethodInfo[] handlers) +175
System.Web.HttpApplication.InitSpecial(HttpApplicationState state, MethodInfo[] handlers, IntPtr appContext, HttpContext context) +304
System.Web.HttpApplicationFactory.GetSpecialApplicationInstance(IntPtr appContext, HttpContext context) +404
System.Web.Hosting.PipelineRuntime.InitializeApplication(IntPtr appContext) +475
System.Web.HttpRuntime.FirstRequestInit(HttpContext context) +12601936
System.Web.HttpRuntime.EnsureFirstRequestInit(HttpContext context) +159
System.Web.HttpRuntime.ProcessRequestNotificationPrivate(IIS7WorkerRequest wr, HttpContext context) +12441597
Version Information: Microsoft .NET Framework Version:4.0.30319; ASP.NET Version:4.0.30319.34009
پرسیده شده در 1394/07/01 توسط
ببینید تمام سرویس های Exchange server استارت هستند
لاگ ها رو هم بررسی کنید که آیا موردی باعث مسدود شدن ترافیک بین DC و Exchange شده مثلا Firewall، Load Balancing ,..
IP استاتیک ست کردید؟از طریق DC پینگ Exchange Server رو دارید؟
پاسخ در 1394/07/01 توسط
