نبودن فولدر NetLogon در شبکه دومین و مشکل GPUpdate
بپرسید
  • parviz_p_t parviz_p_t
  • 101 ماه قبل
  • 101 ماه قبل
  • 367 نمایش
سلام دوستان ، 2012 رو به عنوان Additional برای 2008 بالا آوردم. هرکاری می کردم 2008 ، demote نمی شد . 2008 رو خاموش کردم و همه رولها رو انتقال دادم و Seize کردم . برای 2012 ، یه 2012 دیگه به عنوان Additional بالا آوردم . در هیچ کدوم از این مراحل خطا نداشتم .حلا در اجرای gpupdate /force این خطا رو میده:
Computer policy could not be updated <left>
successfully. The following errors were enc
ountered:
The processing of Group Policy failed. Windows could not apply the registry-based policy settings for the Group Policy object LDAP://CN=Machine,CN={31B2F340-016
D-11D2-945F-00C04FB984F9},CN=Policies,CN=System,DC=MY DOMAIN,DC=.LOCAL. Group Policy settings will not be resolved until
this event is resolved. View the event details
for more information on the file name and path that caused the failure.
User Policy update has completed successfully.
To diagnose the failure, review the event log or run GPRESULT /H GPReport.html f
rom the command line to access information about Group Policy results.
این هم نتیجه dcdiag:
Microsoft Windows [Version 6.3.9600<left>
(c) 2013 Microsoft Corporation. All rights reserved.
C:\Windows\system32>DCDIAG
Directory Server Diagnosis
Performing initial setup:
Trying to find home server...
Home Server = PDC2012
* Identified AD Forest.
Done gathering initial info.
Doing initial required tests
Testing server: Default-First-Site-Name\PDC2012
Starting test: Connectivity
......................... PDC2012 passed test Connectivity
Doing primary tests
Starting test: Advertising
......................... PDC2012 passed test Advertising
Starting test: FrsEvent
There are warning or error events within the last 24 hours after the
SYSVOL has been shared. Failing SYSVOL replication problems may cause
Group Policy problems.
......................... PDC2012 passed test FrsEvent
Starting test: DFSREvent
......................... PDC2012 passed test DFSREvent
Starting test: SysVolCheck
......................... PDC2012 passed test SysVolCheck
Starting test: KccEvent
......................... PDC2012 passed test KccEvent
Starting test: KnowsOfRoleHolders
......................... PDC2012 passed test KnowsOfRoleHolders
Starting test: MachineAccount
......................... PDC2012 passed test MachineAccount
Starting test: NCSecDesc
......................... PDC2012 passed test NCSecDesc
Starting test: NetLogons
Unable to connect to the NETLOGON share! (\\PDC2012\netlogon)
[PDC2012] An net use or LsaPolicy operation failed with error 67,
The network name cannot be found..
......................... PDC2012 failed test NetLogons
Starting test: ObjectsReplicated
......................... PDC2012 passed test ObjectsReplicated
Starting test: Replications
......................... PDC2012 passed test Replications
Starting test: RidManager
......................... PDC2012 passed test RidManager
Starting test: Services
......................... PDC2012 passed test Services
Starting test: SystemLog
An error event occurred. EventID: 0x00000448
Time Generated: 01042016 19:53:51
Event String:
31B2F340-016D-11D2-945F-00C04FB984F9},CN=Policies,CN=System,DC=MYDOMAIN,DC=LOCAL. Gro
up Policy settings will not be resolved until this event is resolved. View the e
vent details for more information on the file name and path that caused the fail
ure.
Time Generated: 01042016 19:58:51
Event String:
ure.
A warning event occurred. EventID: 0x000003F6
Time Generated: 01042016 20:00:13
Event String:
Name resolution for the name sqm.telemetry.microsoft.com timed out a
fter none of the configured DNS servers responded.
A warning event occurred. EventID: 0x000727A5
Time Generated: 01042016 20:00:57
Event String:
The WinRM service is not listening for WS-Management requests.
A warning event occurred. EventID: 0x80003E81
Time Generated: 01042016 20:10:05
Event String:
A TDI filter (\Driver\vnetflt) was detected. This filter has not bee
n certified by Microsoft and may cause system instability.
An error event occurred. EventID: 0x0000164A
Time Generated: 01042016 20:10:27
Event String:
The Netlogon service could not create server share C:\Windows\SYSVOL
\sysvol\MYDOMAIN.LOCAL\SCRIPTS. The following error occurred:
A warning event occurred. EventID: 0x00001796
Event String:
Microsoft Windows Server has detected that NTLM authentication is pr
esently being used between clients and this server. This event occurs once per b
oot of the server on the first time a client uses NTLM with this server.
Time Generated: 01042016 20:10:49
Event String:
31B2F340-016D-11D2-945F-00C04FB984F9},CN=Policies,CN=System,MYDOMAIN,DC=LOCAL. Gro
ure.
A warning event occurred. EventID: 0x0000000C
Time Generated: 01042016 20:10:53
Event String:
Time Provider NtpClient: This machine is configured to use the domai
n hierarchy to determine its time source, but it is the AD PDC emulator for the
domain at the root of the forest, so there is no machine above it in the domain
hierarchy to use as a time source. It is recommended that you either configure a
reliable time service in the root domain, or manually configure the AD PDC to s
ynchronize with an external time source. Otherwise, this machine will function a
s the authoritative time source in the domain hierarchy. If an external time sou
rce is not configured or used for this computer, you may choose to disable the N
tpClient.
Time Generated: 01042016 20:13:28
Event String:
Time Generated: 01042016 20:15:50
Event String:
ure.
Time Generated: 01042016 20:20:50
Event String:
ure.
Time Generated: 01042016 20:25:50
Event String:
ure.
Time Generated: 01042016 20:27:15
Event String:
ure.
Time Generated: 01042016 20:32:15
Event String:
ure.
Time Generated: 01042016 20:37:15
Event String:
ure.
Time Generated: 01042016 20:42:15
Event String:
ure.
Time Generated: 01042016 20:47:15
Event String:
ure.
Time Generated: 01042016 20:48:15
Event String:
ure.
Time Generated: 01042016 20:48:41
Event String:
ure.
......................... PDC2012 failed test SystemLog
Starting test: VerifyReferences
......................... PDC2012 passed test VerifyReferences
Running partition tests on : ForestDnsZones
Starting test: CheckSDRefDom
......................... ForestDnsZones passed test CheckSDRefDom
Starting test: CrossRefValidation
CrossRefValidation
Running partition tests on : DomainDnsZones
......................... DomainDnsZones passed test CheckSDRefDom
CrossRefValidation
Running partition tests on : Schema
......................... Schema passed test CheckSDRefDom
......................... Schema passed test CrossRefValidation
Running partition tests on : Configuration
......................... Configuration passed test CheckSDRefDom
......................... Configuration passed test CrossRefValidation
Running partition tests on : MYDOMAIN
......................... MYDOMAIN passed test CheckSDRefDom
......................... MYDOMAIN passed test CrossRefValidation
Running enterprise tests on : MYDOMAIN.LOCAL
Starting test: LocatorCheck
......................... MYDOMAIN.LOCAL passed test LocatorCheck
Starting test: Intersite
......................... MYDOMAIN.LOCAL passed test Intersite
C:\Windows\system32>^A
در replicate خطایی دیده نشد . ضمنا فولدر Netlogon هم ندارم ، ممنون می شم اگر راهنمایی داشته باشید.اگر مشکل اساسیه، آیا با نصب یک Additional دیگه و خارج کردن pdc کنونی و تبدیل این Additional به pdc مشکل حل می شه؟
پاسخ ها به این سوال
پاسخ ها به این سوال
{{ digitTrunc(post.likes) }}
{{ err }}
