پورت های سوِیچ
دوستان منظور از TS ,PS,WS در کنار معرفی پورت سویچ چیست؟
مثلا Cisco Catalyst 3750G-12S
Cisco Catalyst 3750G-24PS
Cisco Catalyst 3750-48TS
پرسیده شده در 1395/09/02 توسط
TT — common port and uplink port are both BaseT;
LC — common port is BaseT and partially support PoE(4 ports) uplink port are BaseT/SFP;
PC — common port is BaseT and all support PoE(24 ports) uplink port are BaseT/SFP;
TC –common port is BaseT and uplink port are all BaseT/SFP;
TS — common port is BaseT and uplink port are all SFP;
PS — common port is BaseT and all support the PoE, uplink port are all SFP;
FS — common port is 100BaseFX and uplink port are all SFP;
این لینک هم میتونه کمکنون کنه
http://www.fiber-optic-tutorial.com/explanation-of-the-model-of-cisco-switches.html
پاسخ در 1395/09/03 توسط
در مورد مدل های مختلف سوییچ های سیسکو توضیخ داده شده :
https://www.productsandservices.bt.combtbusinessbtbusinessProductspdfscisco3560qa.pdf
