مشکل در ارسال ایمیل توسط میل سرور MDaemon
لطفا در خصوص خطای زیر راهنمایی بفرمایید
لازم به ذکر است در میل سرور راه اندازی شده تمامی رکوردها تنظیم شده و از هر سرویس دهنده ای میتواند ایمیل دریافت کند ولی توسط zen.spamhaus.org لیست شده و اجازه ارسال ندارد.
= Greetings from the MDaemon mail system at mail.***********.ir =
The following message:
Session-ID: 001573 (specific to this delivery attempt)
Queue-ID: pd35000000026.msg
Message-ID: WC********00A@*****************.ir
could not be delivered to the following recipient(s):
mxtoolbox@mxtoolbox.com (unrecoverable error)
despite one or more unsuccessful attempts to do so.
No further delivery attempts will be made and the message has been removed from the queue.
The original message headers follow at the end of this report. For information on DSN messages see http://www.altn.comdsn.
Please quote the Queue-ID, Session-ID, and Message-ID found above in any inquiries regarding this message.
= Session Transcript =
Session 001573; child 0001
Parsing message <xxxxxxxxxxxxxxxxxxxxxxxx\pd35000000026.msg>
* To: mxtoolbox@mxtoolbox.com
* Subject: dear suport team
* Size (bytes): 1035
Message-ID: &lt;WC20171013132125.67000A@*********.ir>
Resolving MX record for mxtoolbox.com (DNS Server: 8.8.4.4)...
* P=001 S=001 D=mxtoolbox.com TTL=(56) MX=[aspmx.l.google.com]
* P=005 S=000 D=mxtoolbox.com TTL=(56) MX=[alt2.aspmx.l.google.com]
* P=005 S=004 D=mxtoolbox.com TTL=(56) MX=[alt1.aspmx.l.google.com]
* P=010 S=002 D=mxtoolbox.com TTL=(56) MX=[aspmx2.googlemail.com]
* P=010 S=003 D=mxtoolbox.com TTL=(56) MX=[aspmx3.googlemail.com]
Attempting SMTP connection to aspmx.l.google.com
Resolving A record for aspmx.l.google.com (DNS Server: 8.8.4.4)...
* D=aspmx.l.google.com TTL=(1) A=[173.194.222.26]
Attempting SMTP connection to 173.194.222.26:25
Waiting for socket connection...
Connection established 192.168..:*** --> 173.194.222.26:25
Waiting for protocol to start...
<-- 220 mx.google.com ESMTP s62si327403lfg.491 - gsmtp
--> EHLO mail.**********.ir
<-- 250-mx.google.com at your service, [37.**.**.**]
<-- 250-SIZE 20971520
<-- 250-8BITMIME
<-- 250-STARTTLS
<-- 250-ENHANCEDSTATUSCODES
<-- 250 SMTPUTF8
--> MAIL From:<admin@*************.ir> SIZE=1035
<-- 250 2.1.0 OK s62si327403lfg.491 - gsmtp
--> RCPT To:<mxtoolbox@mxtoolbox.com>
<-- 250 2.1.5 OK s62si327403lfg.491 - gsmtp
--> DATA
<-- 354 end data with <CR><LF>.<CR><LF>
Sending <xxxxxxxxxxxxxxxxxxxxxxxx\pd35000000026.msg> to [173.194.222.26]
Transfer Complete
<-- 554 5.7.1 Message refused by DNSBL check. zen.spamhaus.org / 37.**.**.** This email from IP 37.**.**.** has been rejected. The email message was detected as spam.
--> QUIT
= End Transcript =
Reporting-MTA: dns; mail.**************.ir
Arrival-Date: Fri, 13 Oct 2017 06:21:26 -0700
X-MDaemon-Version: 17.0.2
Final-Recipient: rfc822; mxtoolbox@mxtoolbox.com
Last-Attempt-Date: Fri, 13 Oct 2017 06:21:28 -0700
Remote-MTA: dns; aspmx.l.google.com
Diagnostic-Code: smtp; 554 5.7.1 Message refused by DNSBL check. zen.spamhaus.org / 37.**.**.** This email from IP 37.**.**.** has been rejected. The email message was detected as spam.
Status: 5.7.1
Action: failed
پرسیده شده در 1396/07/23 توسط
8 پاسخ
دوست عزیز Mdaemon مشکلی ندارد. فقط IP Addressای که ایمیل های شما ارسال می شود SPAM شناخته می شود.(IP با 37 شروع می شود) حال بررسی نمائید آیا این برای MX دومین شما تعریف شده است یا خیر.
می توانید از روی سرور Mdaemon بررسی نمائید که با چه Public IP به اینترنت دسترسی دارد. (با استفاده whatismyipaddress). سپس بررسی کنید که آیا همین IP برای ایمیل دومین شما تنظیم شده است. (با کمک از mxtoolbox.com)
اگر یکی نبودند اصلاح نمائید. یعنی Mdaemon با همان IP که برای MX Record دومین شما تعریف شده به اینترنت دسترسی داشته باشد.
اگر هم یکی بودند متاسفانه IP شما در Black List قرار گرفته است. مکاتبه جهت رفع انسداد و تغییر MX می تواند راهکار آن باشد.
پاسخ در 1396/07/23 توسط
سلام مهندسین عزیز
یه سوال خدمتتون داشتم
در سازمانمون قبلا از طریق نرم افزار Mdaemon ایمیل ایجاد کرده بودند که من استخدام اون سازمان نبودم لذا پس از استخدام در این سازمان ایمیل ها را تحویل گرفتم مشکلی نبود لذا یکبار سرور کامل خاموش شده و مجدد روشن شد
پس از اون کرک نرم افزا پرید و مجبور به نصب ورژن بالا تر و کرک برنامه شدیم
حال ارسال ایمیلها درون سازمانی مشکلی نداره ولی به بیرون از سازمان نه ارسال و نه دریافت میکنه
چطور میتونید کمک کنید
ممنون میشم کمکم کنید خیلی واجبه
درضمن از کریو هم استفاده میکنیم
همه چی رو چک کردم ولی فایده نکرده
سپاس بی کران
پاسخ در 1398/02/22 توسط
دوستان سلام
من چند روزی است که دامنه www.arshekaran.com را خریداری و dns هاست را بر روی دامنه ست کرده ام اما در هنگام ورود به سایت به جای نام دامنه آدرس ip نمایش داده می شود . http://185.2.12.70~zznaidxo
دلیل چیست هر چه سعی میکنم درست نمیشود . کسب میتواند کمک نماید
پاسخ در 1398/01/04 توسط
دوست عزیز
ممنون از توجه و راهنمایی مفیدتان
مشکل من در حذف از لیست، استفاده از ایمیل غیر سازمانی بود و به محض استفاده از ایمیل سازمانی سیستم منو از لیست سیاه حذف کرد.
با تشکر مجدد از راهنمایی و توجه شما.
پاسخ در 1396/07/25 توسط
دوست عزیز
ابتدا از وضعیت MX Record خود اطمینان حاصل کنید.
نکته بعدی فعال بودن SMTP Authentication در Mdaemon است.
Security--- Security Settings ---- Sender Authentication --- SMTP Authentication
را باز نمائید و گزینه Authentication is always required when mail is from local accounts را فعال نمائید. تنظیمات Outlook در کلاینت ها نیز می بایست فعال گردد.
سپس فرم مربوطه را به صورت دقیق پر کنید. حتما از ایمیل سازمانی خود استفاده نمائید.
سلام و درود
چند نکته:
شما چندوقت است که این Mail Server را راه اندازی نمودید؟
آیا پیش از راه اندازی وضعیت IP را از نظر Black List چک کرده بودید؟
هدف من از این سوالات پیدا نمودن دلیل این اتفاق است. شاید این IP قبلا جزو Black List قرار گرفته باشد. راهکار این می تواند تغییر IP برای MX باشد.
اما اگر این IP بعد از استفاده توسط Mail Server شما به Black List اضافه شده باشد، ابتدا بایستی دلیل آن را پیدا نمائید. سپس مشکل را برطرف کنید. بعد با مکاتبه و یا تغییر IP شرایط را تغییر دهید.
سلام مجدد
این ایمیل سرور دو ماهه که راه اندازی شده و آی پی قبلا در بلک لیست نبود
پیام سایت لیست کننده آی پی در زیر آمده
Ref: PBL152****
37.**.**./* is listed on the Policy Block List (PBL)
Outbound Email Policy of The Spamhaus Project for this IP range:
This IP address range has been identified by Spamhaus as not meeting our policy for IP addresses permitted to deliver unauthenticated 'direct-to-mx' email to PBL users.
Important: If you are using any normal email software (such as Outlook, Entourage, Thunderbird, Apple Mail, etc.) and you are being blocked by this Spamhaus PBL listing when you try to send email, the reason is simply that you need to turn on "SMTP Authentication" in your email program settings. For help with SMTP Authentication or ways to quickly fix this problem click here.
Policy Block List
PBL Self-Service IP Removal
Automatic removal mechanism for single Static IP addresses
This function allows mail server operators with Static IP addresses listed on the PBL (such as IPs within a range previously identified as Dynamic but which has been recently reassigned as Static) to automatically remove their Static IP addresses from the PBL database.
Before removing an IP address from the PBL database you must understand this:
THE PBL IS NOT A BLACKLIST. You are not blacklisted for spamming or for anything you have done. The PBL is simply a list of ALL of the world's end-user broadband IP space, i.e: IP space normally assigned to broadband/ADSL customers. It is perfectly normal for dynamic IP addresses (DSL, DHCP, cable, dialup) to be listed on the PBL. In fact all IP addresses in the world which are not designated mail server machines should be on the PBL.
The PBL does not prevent you sending email unless your email program is not authenticating properly when it connects to your ISP or company's mail server. This can happen if you have forgotten to turn on 'Authentication' in your 'outgoing mail' account settings, or if the username/password your email program is giving to your outgoing mail server is wrong.
If you are using a normal email program, such as Outlook, Entourage, Thunderbird, Apple Mail, and you are being blocked by a Spamhaus PBL listing when you try to send email, the reason is simply that YOU NEED TO TURN ON 'SMTP AUTHENTICATION' in your email program's account settings. See: How do I turn on SMTP Authentication?
You should only remove an IP address from the PBL if (A) the IP address is Static and has proper Reverse DNS assigned to your mail server, and (B) if you have a specific technical reason for needing to run a 'direct-to-MX' email service, such as a mail server appliance, off the Static IP address. In all other cases you should NOT remove an IP address from the PBL.
By removing your IP address from the PBL database you are assuming responsibility for any Spam that may later originate from the IP address. If spam is then detected from an IP address excluded from PBL, it may be listed in SBL or XBL under the criteria of those lists.
When requesting a removal, do NOT give a Freemail or free webmail address (such as @gmail.com, @hotmail.com, @yahoo.com, etc). The PBL system does not process removals from freemail accounts (the system will simply discard any removals you make if you use any 'freemail' address). Always use your real address and your own domain.
You can not remove an IP address that is also listed in another Spamhaus database (such as SBL or XBL) due to other existing spam issues. You can not remove an IP address that has been set to 'non-removable' by your ISP. In this case you need to contact your ISP to resolve the issue.
Removed IP addresses are not actually deleted from the PBL master database, instead they are added to a suppression database which removes the IP address from the current PBL zone build. You can only remove one IP address. Safeguards are built in to prevent abuse of the removal facility by spammers (and particularly by automated bots).
<ltr><left>
بعد از ورود به صفحه حذف آی پی از لیست مربوطه پیام زیر میاد
Policy Block List
Failed
The IP address removal process failed for the following reason:
Removal not allowed
ممنون از توجه شما
تاکید میکنم که همه رکوردها ایجاد شده و آیپی خروجی با آیپی استاتیک رزرو شده برای میل سرور یکی می باشد. فقط با تمام مراجعات برای خروج از لیست سایت مذکور موفق نشدم.
اگر راهکار تخصصی مد نظر دوستان هست راهنمایی بفرمایند.
پاسخ در 1396/07/24 توسط
