جلوگیری از Anti-spoofing در کریو
در کریو کنترل در قسمت security Log لاگ های به صورت زیر زیاد تولید میشود که باعث پر شدن فضای هارد کریو میشود لطفا راهنمایی کنید که چگونه این مشکل را حل کنم.
[02May2018 09:30:23] Anti-spoofing: Packet from LAN, proto:UDP, len:381, 192.168.1.37:3842 -> 239.255.255.250:1900, udplen:353
[02May2018 09:30:23] Anti-spoofing: Packet from LAN, proto:UDP, len:387, 192.168.1.37:3842 -> 239.255.255.250:1900, udplen:359
[02May2018 09:30:23] Anti-spoofing: Packet from LAN, proto:UDP, len:427, 192.168.1.37:3842 -> 239.255.255.250:1900, udplen:399
[02May2018 09:30:23] Anti-spoofing: Packet from LAN, proto:UDP, len:431, 192.168.1.37:3842 -> 239.255.255.250:1900, udplen:403
[02May2018 09:30:24] Anti-spoofing: Packet from LAN, proto:UDP, len:431, 192.168.1.37:3842 -> 239.255.255.250:1900, udplen:403
[02May2018 09:30:27] Anti-spoofing: Packet from LAN, proto:UDP, len:381, 192.168.1.43:3117 -> 239.255.255.250:1900, udplen:353
[02May2018 09:30:27] Anti-spoofing: Packet from LAN, proto:UDP, len:387, 192.168.1.43:3117 -> 239.255.255.250:1900, udplen:359
[02May2018 09:30:27] Anti-spoofing: Packet from LAN, proto:UDP, len:427, 192.168.1.43:3117 -> 239.255.255.250:1900, udplen:399
[02May2018 09:30:27] Anti-spoofing: Packet from LAN, proto:UDP, len:431, 192.168.1.43:3117 -> 239.255.255.250:1900, udplen:403
[02May2018 09:30:27] Anti-spoofing: Packet from LAN, proto:UDP, len:431, 192.168.1.43:3118 -> 239.255.255.250:1900, udplen:403
[02May2018 09:30:33] Anti-spoofing: Packet from LAN, proto:UDP, len:381, 192.168.1.26:3125 -> 239.255.255.250:1900, udplen:353
[02May2018 09:30:33] Anti-spoofing: Packet from LAN, proto:UDP, len:381, 192.168.1.45:3138 -> 239.255.255.250:1900, udplen:353
[02May2018 09:30:33] Anti-spoofing: Packet from LAN, proto:UDP, len:387, 192.168.1.26:3125 -> 239.255.255.250:1900, udplen:359
[02May2018 09:30:33] Anti-spoofing: Packet from LAN, proto:UDP, len:381, 192.168.1.34:3145 -> 239.255.255.250:1900, udplen:353
[02May2018 09:30:33] Anti-spoofing: Packet from LAN, proto:UDP, len:387, 192.168.1.45:3138 -> 239.255.255.250:1900, udplen:359
[02May2018 09:30:33] Anti-spoofing: Packet from LAN, proto:UDP, len:427, 192.168.1.26:3125 -> 239.255.255.250:1900, udplen:399
[02May2018 09:30:33] Anti-spoofing: Packet from LAN, proto:UDP, len:387, 192.168.1.34:3145 -> 239.255.255.250:1900, udplen:359
[02May2018 09:30:33] Anti-spoofing: Packet from LAN, proto:UDP, len:431, 192.168.1.26:3125 -> 239.255.255.250:1900, udplen:403
[02May2018 09:30:33] Anti-spoofing: Packet from LAN, proto:UDP, len:427, 192.168.1.45:3138 -> 239.255.255.250:1900, udplen:399
[02May2018 09:30:33] Anti-spoofing: Packet from LAN, proto:UDP, len:427, 192.168.1.34:3145 -> 239.255.255.250:1900, udplen:399
[02May2018 09:30:33] Anti-spoofing: Packet from LAN, proto:UDP, len:431, 192.168.1.45:3138 -> 239.255.255.250:1900, udplen:403
[02May2018 09:30:33] Anti-spoofing: Packet from LAN, proto:UDP, len:431, 192.168.1.34:3145 -> 239.255.255.250:1900, udplen:403
[02May2018 09:30:34] Anti-spoofing: Packet from LAN, proto:UDP, len:381, 192.168.1.50:3138 -> 239.255.255.250:1900, udplen:353
[02May2018 09:30:34] Anti-spoofing: Packet from LAN, proto:UDP, len:387, 192.168.1.50:3138 -> 239.255.255.250:1900, udplen:359
[02May2018 09:30:34] Anti-spoofing: Packet from LAN, proto:UDP, len:427, 192.168.1.50:3138 -> 239.255.255.250:1900, udplen:399
[02May2018 09:30:34] Anti-spoofing: Packet from LAN, proto:UDP, len:431, 192.168.1.50:3138 -> 239.255.255.250:1900, udplen:403
[02May2018 09:30:34] Anti-spoofing: Packet from LAN, proto:UDP, len:380, 192.168.1.4:3126 -> 239.255.255.250:1900, udplen:352
[02May2018 09:30:34] Anti-spoofing: Packet from LAN, proto:UDP, len:386, 192.168.1.4:3126 -> 239.255.255.250:1900, udplen:358
[02May2018 09:30:35] Anti-spoofing: Packet from LAN, proto:UDP, len:426, 192.168.1.4:3126 -> 239.255.255.250:1900, udplen:398
[02May2018 09:30:35] Anti-spoofing: Packet from LAN, proto:UDP, len:430, 192.168.1.4:3126 -> 239.255.255.250:1900, udplen:402
[02May2018 09:30:36] Anti-spoofing: Packet from LAN, proto:UDP, len:430, 192.168.1.4:3126 -> 239.255.255.250:1900, udplen:402
[02May2018 09:30:36] Anti-spoofing: Packet from LAN, proto:UDP, len:381, 192.168.1.35:3126 -> 239.255.255.250:1900, udplen:353
[02May2018 09:30:37] Anti-spoofing: Packet from LAN, proto:UDP, len:387, 192.168.1.35:3126 -> 239.255.255.250:1900, udplen:359
[02May2018 09:30:37] Anti-spoofing: Packet from LAN, proto:UDP, len:427, 192.168.1.35:3126 -> 239.255.255.250:1900, udplen:399
[02May2018 09:30:37] Anti-spoofing: Packet from LAN, proto:UDP, len:431, 192.168.1.35:3126 -> 239.255.255.250:1900, udplen:403
[02May2018 09:30:38] Anti-spoofing: Packet from LAN, proto:UDP, len:431, 192.168.1.35:3126 -> 239.255.255.250:1900, udplen:403
[02May2018 09:30:44] Anti-spoofing: Packet from LAN, proto:UDP, len:345, 10.90.90.90:62976 -> 255.255.255.255:62976, udplen:317
اگر اورجینال نیست کریوتون تیک فعال سازی Anti-snofing رو بردارید ...
