خطای RPC is unavailable در باز کردن کنسول مدیریت کاربران AD
با سلام دوستان،وقتی میخام active directory user and computer رو باز کنم پیغام زیر رو میده و باز نمیشه ، dns رو چک کردم به درستی کار میکنه،حتی با اسم میتونم ping هم کنم،dc additional هم میتونه با سرور اصلی replicate کنه و حتی توی additional هم میتونم active directory user and computer رو ببینم اما توی سرور اصلی dcdiag هم گرفتم که نتیجشو میذارم دوستان هم نظر بدن :
Directory Server Diagnosis Performing initial setup:
   Trying to find home server...
   Home Server = dccomputer
   * Identified AD Forest.
   Done gathering initial info.
Doing initial required tests
   Testing server: mydomain\DCCOMPUTER
      Starting test: Connectivity
         ......................... DCCOMPUTER passed test Connectivity
Doing primary tests
      Starting test: Advertising
         Warning: DsGetDcName returned information for \\DC2COMPUTER.mydomain.com,
         when we were trying to reach DCCOMPUTER.
         SERVER IS NOT RESPONDING or IS NOT CONSIDERED SUITABLE.
         ......................... DCCOMPUTER failed test Advertising
      Starting test: FrsEvent
         ......................... DCCOMPUTER passed test FrsEvent
      Starting test: DFSREvent
         ......................... DCCOMPUTER passed test DFSREvent
      Starting test: SysVolCheck
         ......................... DCCOMPUTER passed test SysVolCheck
      Starting test: KccEvent
         ......................... DCCOMPUTER passed test KccEvent
      Starting test: KnowsOfRoleHolders
         ......................... DCCOMPUTER passed test KnowsOfRoleHolders
      Starting test: MachineAccount
         * The current DC is not in the domain controller's OU
         ......................... DCCOMPUTER failed test MachineAccount
      Starting test: NCSecDesc
         ......................... DCCOMPUTER passed test NCSecDesc
      Starting test: NetLogons
         [DCCOMPUTER] User credentials does not have permission to perform this
         operation.
         The account used for this test must have network logon privileges
         for this machine's domain.
         ......................... DCCOMPUTER failed test NetLogons
      Starting test: ObjectsReplicated
         ......................... DCCOMPUTER passed test ObjectsReplicated
      Starting test: Replications
         [Replications Check,DCCOMPUTER] DsReplicaGetInfo(PENDING_OPS, NULL)
         failed, error 0x2105 "Replication access was denied."
         ......................... DCCOMPUTER failed test Replications
      Starting test: RidManager
         ......................... DCCOMPUTER passed test RidManager
      Starting test: Services
            Could not open NTDS Service on DCCOMPUTER, error 0x5
            "Access is denied."
            NETLOGON Service is paused on [DCCOMPUTER]
         ......................... DCCOMPUTER failed test Services
      Starting test: SystemLog
         An error event occurred.  EventID: 0x00000457
            Time Generated: 07/20/2014   09:47:02
            Event String:
            Driver Nitro PDF Driver 2 required for printer Nitro PDF Creator 2 i
s unknown. Contact the administrator to install the driver before you log in aga
in.
            Time Generated: 07/20/2014   09:51:57
            Event String:
in.
            Time Generated: 07/20/2014   09:55:32
            Event String:
in.
            Time Generated: 07/20/2014   10:04:05
            Event String:
in.
         ......................... DCCOMPUTER failed test SystemLog
      Starting test: VerifyReferences
         ......................... DCCOMPUTER passed test VerifyReferences
   Running partition tests on : ForestDnsZones
      Starting test: CheckSDRefDom
         ......................... ForestDnsZones passed test CheckSDRefDom
      Starting test: CrossRefValidation
         CrossRefValidation
   Running partition tests on : DomainDnsZones
         ......................... DomainDnsZones passed test CheckSDRefDom
         CrossRefValidation
   Running partition tests on : Schema
         ......................... Schema passed test CheckSDRefDom
         ......................... Schema passed test CrossRefValidation
   Running partition tests on : Configuration
         ......................... Configuration passed test CheckSDRefDom
         ......................... Configuration passed test CrossRefValidation
   Running partition tests on : mydomain
         ......................... mydomain passed test CheckSDRefDom
         ......................... mydomain passed test CrossRefValidation
   Running enterprise tests on : mydomain.com
      Starting test: LocatorCheck
information cannot be located because RPC server is unavailable.
پرسیده شده در 1393/04/29 توسط
لینک زیر مراجعه فرمایید و در صورت امکان نتیجه را اعلام فرمایید.با هم میروم جلو ببینیم چی میشه
http://social.technet.microsoft.com/wiki/contents/articles/4494.windows-server-troubleshooting-the-rpc-server-is-unavailable.aspx
موفق باشید
پاسخ در 1393/04/30 توسط
سلام دوستان مشکل حل شد،طی جستجوهایی که کردم عوامل زیر میتونه باعث این کار بشه که در زیر میبینید:
SRV records for Active directory domain controllers are not registered in the same Domain DNS Zone as the local computer.
The DNS Server is not reachable for some reason.
LDAP Port 389 is not opened or not listening on the destination Domain Controller.
A (Host) record for Domain Controller is missing in the Domain DNS Zone.
The NetLogon service on Domain Controller is not running.
The local machine is pointing to the wrong DNS Server.
Network port issues if local machine and DNS Server/domain controllers are located in different sites.
DNS Server can’t be contacted because of network congestion.
DNS Servers or Domain Controllers are heavily load
مشکل من عدم استارت سرویس net logon بعد از ریستارت سیستم بود اما این امر عواملی دیگه ای هم داره که در بالا میبینید،ضمنا هر نقطه در بالا یک شماره هستش یعنی جمعا 9 مورد
پاسخ در 1393/05/03 توسط
دوست عزیز در بیش از 90 درصد موارد اشکالاتی که مربوط به RPC میشن به سرویس DNS بستگی دارند ، یه کاری کنید ، اولا مطمئن بشید که آدرس DNS سرور DC ابتدا داره به خودش اشاره می کنه ، دوم بررسی کنید اگر Replication یا Additional دارید یکبار DNS سرورها رو بصورت ضربدری در کارت شبکه تنظیم کنید ، بررسی کنید هر دو DC در لیست NS Record های مجموعه DNS وجود داشته باشن و در نهایت یکبار System Properties بگیرید و در قسمت Computer Name و Change Name گزینه More رو بزنید و مطمئن بشید که اسم Domain شما به اسم DC شما اضافه شده باشه ، موفق باشید
