مشکل در نصب سرویس Exchange 2016 u15
سلام وخسته نباشید
میخواستم ببینم تا حالا دوستان این مشکل رو بر خورد کردن ؟ من موقع نصب exchange این خطا ها رو میخورم
Error:
This computer doesn't belong to a valid Active Directory site. Check the site and subnet definitions.
For more information, visit: http://technet.microsoft.comlibrary(EXCHG.150)ms.exch.setupreadiness.InvalidADSite.aspx
Error:
A reboot from a previous installation is pending. Please restart the system and then rerun Setup.
For more information, visit: http://technet.microsoft.comlibrary(EXCHG.150)ms.exch.setupreadiness.RebootPending.aspx
Error:
You must be a member of the 'Organization Management' role group or a member of the 'Enterprise Admins' group to continue.
For more information, visit: http://technet.microsoft.comlibrary(EXCHG.150)ms.exch.setupreadiness.GlobalServerInstall.aspx
Error:
You must use an account that's a member of the Organization Management role group to install or upgrade the first Mailbox server role in the topology.
For more information, visit: http://technet.microsoft.comlibrary(EXCHG.150)ms.exch.setupreadiness.DelegatedBridgeheadFirstInstall.aspx
Error:
You must use an account that's a member of the Organization Management role group to install the first Client Access server role in the topology.
For more information, visit: http://technet.microsoft.comlibrary(EXCHG.150)ms.exch.setupreadiness.DelegatedCafeFirstInstall.aspx
Error:
For more information, visit: http://technet.microsoft.comlibrary(EXCHG.150)ms.exch.setupreadiness.DelegatedFrontendTransportFirstInstall.aspx
Error:
For more information, visit: http://technet.microsoft.comlibrary(EXCHG.150)ms.exch.setupreadiness.DelegatedMailboxFirstInstall.aspx
Error:
You must use an account that's a member of the Organization Management role group to install or upgrade the first Client Access server role in the topology.
For more information, visit: http://technet.microsoft.comlibrary(EXCHG.150)ms.exch.setupreadiness.DelegatedClientAccessFirstInstall.aspx
Error:
You must use an account that's a member of the Organization Management role group to install the first Mailbox server role in the topology.
For more information, visit: http://technet.microsoft.comlibrary(EXCHG.150)ms.exch.setupreadiness.DelegatedUnifiedMessagingFirstInstall.aspx
Error:
Setup encountered a problem while validating the state of Active Directory: Could not find information about the local site. This can be caused by incorrect configuration of subnets or sites or by replication latency. See the Exchange setup log for more information on this error.
For more information, visit: http://technet.microsoft.comlibrary(EXCHG.150)ms.exch.setupreadiness.AdInitErrorRule.aspx
Error:
Either Active Directory doesn't exist, or it can't be contacted.
For more information, visit: http://technet.microsoft.comlibrary(EXCHG.150)ms.exch.setupreadiness.CannotAccessAD.aspx
این هم بگم روی اکتیو هام ( 2 اکتیور و 2 تا RODC ) اومدم فریومفورک روی روی اصلی ها ورژن 4.7.1 رو نصبکردم و این دستورات رو زدم روی اکتیور
Setup.exe PrepareSchema IAcceptExchangeServerLicenseTerms
Setup.exe PrepareAD OrganizationName:"CRA" /IAcceptExchangeServerLicenseTerms
و حتی
Setup.exe PrepareAllDomains IAcceptExchangeServerLicenseTerms
این رو هم میزنم اما باز هم خطا های بالا رو روی سرور میده ! موارد نصب هم اخرین ورژن هست و آپدیت ها
حتی با یوزر enterprise میام ها که گفته اما جواب نمیده
ممنون میشم جواب بدین
پرسیده شده در 1397/10/09 توسط
من سوالم رو بد میپرسم یا واقعا کسی بلد نیست جواب بده
پاسخ در 1397/10/10 توسط
