ورود به سیستم بدون دسترسی فیزیکی
سلام.یکی از همکاران من که سیستمش رو روشن میذاره از داخل event viewer متوجه شده که یک نفر وقتی شرکت تعطیل هست وارد سیستمش شده و یک نرم افزار هم داشته که بسته شده.خودم هم چک کردن دیدم درسته و فلان ساعت که کسی تو شرکت نبوده سیستمش لاگین ثبت کرده. من لاگ روتر هم چک کردم دیدم درسته اون ساعت سیستمش کار کرده، نگهبان هم مطمئن هست که کسی داخل شرکت نبوده احتمالش هست از راه های دیگه وارد شده باشن؟
پرسیده شده در 1398/11/26 توسط
10 پاسخ
Log Name:      Security
Source:        Microsoft-Windows-Security-Auditing
Date:          02/12/2020 02:26:43 ق.ظ
Event ID:      4624
Task Category: Logon
Level:         Information
Keywords:      Audit Success
User:          N/A
Computer:      user-PC
Description:
An account was successfully logged on.
Subject:
 Security ID:  SYSTEM
 Account Name:  user-PC
 Account Domain:  WORKGROUP
 Logon ID:  0x3e7
Logon Type:   5
New Logon:
 Security ID:  SYSTEM
 Account Name:  SYSTEM
 Account Domain:  NT AUTHORITY
 Logon ID:  0x3e7
 Logon GUID:  {00000000-0000-0000-0000-000000000000}
Process Information:
 Process ID:  0x310
 Process Name:  C:\Windows\System32\services.exe
Network Information:
 Workstation Name:
 Source Network Address: -
 Source Port:  -
Detailed Authentication Information:
 Logon Process:  Advapi
 Authentication Package: Negotiate
 Transited Services: -
 Package Name (NTLM only): -
 Key Length:  0
This event is generated when a logon session is created. It is generated on the computer that was accessed.
The subject fields indicate the account on the local system which requested the logon. This is most commonly a service such as the Server service, or a local process such as Winlogon.exe or Services.exe.
The logon type field indicates the kind of logon that occurred. The most common types are 2 (interactive) and 3 (network).
The New Logon fields indicate the account for whom the new logon was created, i.e. the account that was logged on.
The network fields indicate where a remote logon request originated. Workstation name is not always available and may be left blank in some cases.
The authentication information fields provide detailed information about this specific logon request.
 - Logon GUID is a unique identifier that can be used to correlate this event with a KDC event.
 - Transited services indicate which intermediate services have participated in this logon request.
 - Package name indicates which sub-protocol was used among the NTLM protocols.
 - Key length indicates the length of the generated session key. This will be 0 if no session key was requested.
Event Xml:
    4624
    0x8020000000000000
    182532
    Security
    Planing-PC
    S-1-5-18
    user-PC$
    WORKGROUP
    0x3e7
    S-1-5-18
    SYSTEM
    NT AUTHORITY
    0x3e7
    5
    Advapi
    Negotiate
    0x310
پاسخ در 1398/11/27 توسط
متشکر. پس شخصی وارد سیستم نشده ؟
پاسخ در 1398/11/28 توسط
Logon type عدد 5 بوده و لاگین با سطح دسترسی SYSTEM انجام شده. احتمالا سرویسی چیزی برای انجام دادن کارش به صورت Interactive احرازهویت شده و کارش رو انجام داده.
خیر
از کجا میتونم اطلاعات بیشتر بگیرم در این مورد که به شرکت ارائه بدم؟
از گوگل ;)
