رفع خطای trust between workstation and primary domain failed
با سلام و احترام
در شبکه دامینی یک سیستم دارم که ویندوزش تازه عوض شده و عضو دامین شده ولی زمانی که میخوام با کاربر دامینی بهش لاگین کنم خطای
trust between workstation and primary domain failed نمایش داده میشود.
یوزر و اکانت کامپیوتر رو بررسی کردم و مشکلی نداره. ping دامین روهم دارم و همچنان مشکل پابرجاست.
ممنون میشم راهنمایی بفرمایید.
پرسیده شده در 1400/11/19 توسط
            [DC] DsReplicaGetInfo(KCC_DS_CONNECT_FAILURES) failed with error 8453,
         [DC] No security related replication errors were found on this DC!  To target the connection to a specific
         source DC use /ReplSource:<DC>.
         [DC] User credentials does not have permission to perform this operation.
         The account used for this test must have network logon privileges
         for this machine's domain.
         ......................... DC failed test NetLogons
         ** Did not run Outbound Secure Channels test because /testdomain: was not entered
         [Replications Check,DC] DsReplicaGetInfo(PENDING_OPS, NULL) failed, error 0x2105
         "Replication access was denied."
         ......................... DC failed test Replications
            Could not open NTDS Service on DC, error 0x5 "Access is denied."
         ......................... DC failed test Services
         ......................... DC failed test SystemLog
         Fatal Error:DsGetDcName (BDC) call failed, error 1722
         The Locator could not find the server.
         ......................... BDC failed test Advertising
         Could not open pipe with [BDC]:failed with 1396: The target account name is incorrect.
         Could not get NetBIOSDomainName
         Failed can not test for HOST SPN
         [BDC] No security related replication errors were found on this DC!  To target the connection to a specific
         The event log DFS Replication on server ...... could not be queried, error 0x6ba
         "The RPC server is unavailable."
         ......................... BDC failed test DFSREvent
         [BDC] An net use or LsaPolicy operation failed with error 64,
         The specified network name is no longer available..
         ......................... BDC failed test SysVolCheck
         ......................... BDC failed test FrsSysVol
         The event log Directory Service on server ......... could not be queried, error 0x6ba
         ......................... BDC failed test KccEvent
         Could not open pipe with [BDC]:failed with 64: The specified network name is no longer available.
         ......................... BDC failed test NetLogons
         The event log System on server ...... could not be queried, error 0x6ba
         ......................... BDC failed test SystemLog
                  ......................... DC failed test DNS
         ......................... BDC failed test DNS
         Test results for domain controllers:
            DC:
            Domain:
               TEST: Authentication (Auth)
                  Error: Authentication failed with specified credentials
               TEST: Basic (Basc)
                  Error: No WMI connectivity
                  No host records (A or AAAA) were found for this DC
         Summary of DNS test results:
                                            Auth Basc Forw Del  Dyn  RReg Ext
            _________________________________________________________________
            Domain:
               BDC                          FAIL FAIL n/a  n/a  n/a  n/a  n/a
         .........................  failed test DNS
پاسخ در 1400/11/21 توسط
DNS ها چجوری ست شدن روی DC ها ؟ هر DC باید اول به DC دیگه و بعد به خودش (127.0.0.1) به عنوان DNS دوم اشاره کنه. لطفا از DNS های خارجی مثل 8.8.8.8 و ... روی سرور ها و دامین کنترلر ها استفاده نکنید. خروجی ipconfig /all رو لطفا ارسال کنید. روی همه DC ها این دستور رو ارسال کنید.
دستور بالا رو روی همه DC ها اجرا کنید. لطفا از قسمت "پاراگراف-> بلوک ها-> کد" برای ارسال خروجی استفاده کنید و یا اینکه توی Dropbox ای چیزی آپلود کنید ، لطفا.
پاسخ در 1400/11/24 توسط
با توجه به خروجی DCDiag تون به نظر میرسه DCDiag رو با دسترسی Domain Admin اجرا نکردید. لطفا Run as کنید و یوزرنیم و پسورد یوزر DA رو وارد کنید.
چند تا DC دارید ؟ RODC هم دارید ؟ سیستم عامل DC ها چی هستن ؟
Event Log ها چی میگن ؟
تایم کلاینت با DC هماهنگ هست ؟
خروجی دستور زیر رو لطفا ارسال کنید :
DCDiag /c /v /e /q
دستور بالا رو روی همه DC ها اجرا کنید. لطفا از قسمت "پاراگراف-> بلوک ها-> کد" برای ارسال خروجی استفاده کنید و یا اینکه توی Dropbox ای چیزی آپلود کنید ، لطفا. متشکرم
پاسخ در 1400/11/20 توسط
احتمال داره مشکل از  Computer name باشه یعنی اسمش با یه کامپیوتر دیگه یکی شده
dis join کن بعد با یه اسم دیگه جوین کن باید درست بشه
