خطا در اکتیودایرکتوری
سلام .من اکتیودارکتوری خود رو با دستور dcdiag تست کردم و چند مورد خطا داره لطفا بگین چطوری این خطا رو رفع کنم
Directory Server Diagnosis
Performing initial setup:
   Trying to find home server...
   Home Server = SERVER-AC2012
   * Identified AD Forest.
   Done gathering initial info.
Doing initial required tests
   Testing server: Default-First-Site-Name\SERVER-AC2012
      Starting test: Connectivity
         ......................... SERVER-AC2012 passed test Connectivity
Doing primary tests
      Starting test: Advertising
         Warning: SERVER-AC2012 is not advertising as a time server.
         ......................... SERVER-AC2012 failed test Advertising
      Starting test: FrsEvent
         ......................... SERVER-AC2012 passed test FrsEvent
      Starting test: DFSREvent
         There are warning or error events within the last 24 hours after the SYSVOL has been shared.  Failing SYSVOL
         replication problems may cause Group Policy problems.
         ......................... SERVER-AC2012 failed test DFSREvent
      Starting test: SysVolCheck
         ......................... SERVER-AC2012 passed test SysVolCheck
      Starting test: KccEvent
         ......................... SERVER-AC2012 passed test KccEvent
      Starting test: KnowsOfRoleHolders
         ......................... SERVER-AC2012 passed test KnowsOfRoleHolders
      Starting test: MachineAccount
         ......................... SERVER-AC2012 passed test MachineAccount
      Starting test: NCSecDesc
         ......................... SERVER-AC2012 passed test NCSecDesc
      Starting test: NetLogons
         ......................... SERVER-AC2012 passed test NetLogons
      Starting test: ObjectsReplicated
         ......................... SERVER-AC2012 passed test ObjectsReplicated
      Starting test: Replications
         [Replications Check,SERVER-AC2012] A recent replication attempt failed:
            From SERVER2016DC2 to SERVER-AC2012
            Naming Context: DC=ForestDnsZones,DC=khayam,DC=local
            The replication generated an error (1256):
            The remote system is not available. For information about network troubleshooting, see Windows Help.
            The failure occurred at 2022-08-07 19:18:02.
            The last success occurred at 2020-06-11 08:19:29.
            19062 failures have occurred since the last success.
         [SERVER2016DC2] DsBindWithSpnEx() failed with error -2146893022,
         The target principal name is incorrect..
         [SERVER2019DC2] DsBindWithSpnEx() failed with error 1398,
         There is a time and/or date difference between the client and server..
            Naming Context: DC=DomainDnsZones,DC=khayam,DC=local
            Naming Context: CN=Schema,CN=Configuration,DC=khayam,DC=local
            The replication generated an error (-2146893022):
            19061 failures have occurred since the last success.
            Naming Context: CN=Configuration,DC=khayam,DC=local
            Naming Context: DC=khayam,DC=local
            The last success occurred at 2020-06-11 08:31:02.
            19059 failures have occurred since the last success.
         ......................... SERVER-AC2012 failed test Replications
      Starting test: RidManager
         ......................... SERVER-AC2012 passed test RidManager
      Starting test: Services
            Invalid service startup type: NETLOGON on SERVER-AC2012, current value DEMAND_START, expected value
            AUTO_START
         ......................... SERVER-AC2012 failed test Services
      Starting test: SystemLog
         An error event occurred.  EventID: 0x40000004
            Time Generated: 08/07/2022   19:01:44
            Event String:
            The Kerberos client received a KRB_AP_ERR_MODIFIED error from the server server2019dc2$. The target name used was KHAYAM\SERVER2016DC2$. This indicates that the target server failed to decrypt the ticket provided by the client. This can occur when the target server principal name (SPN) is registered on an account other than the account the target service is using. Ensure that the target SPN is only registered on the account used by the server. This error can also happen if the target service account password is different than what is configured on the Kerberos Key Distribution Center for that target service. Ensure that the service on the server and the KDC are both configured to use the same password. If the server name is not fully qualified, and the target domain (KHAYAM.LOCAL) is different from the client domain (KHAYAM.LOCAL), check if there are identically named server accounts in these two domains, or use the fully-qualified name to identify the server.
            Time Generated: 08/07/2022   19:18:02
            Event String:
            The Kerberos client received a KRB_AP_ERR_MODIFIED error from the server server2019dc2$. The target name used was E3514235-4B06-11D1-AB04-00C04FC2DCD2/c54ec21c-e264-4cb0-a5ca-4f370c223d22/khayam.local@khayam.local. This indicates that the target server failed to decrypt the ticket provided by the client. This can occur when the target server principal name (SPN) is registered on an account other than the account the target service is using. Ensure that the target SPN is only registered on the account used by the server. This error can also happen if the target service account password is different than what is configured on the Kerberos Key Distribution Center for that target service. Ensure that the service on the server and the KDC are both configured to use the same password. If the server name is not fully qualified, and the target domain (KHAYAM.LOCAL) is different from the client domain (KHAYAM.LOCAL), check if there are identically named server accounts in these two domains, or use the fully-qualified name to identify the server.
         A warning event occurred.  EventID: 0x80000025
            Time Generated: 08/07/2022   19:36:45
            Event String:
            The Key Distribution Center (KDC) encountered a ticket that did not contain information about the account that requested the ticket while processing a request for another ticket. This prevented security checks from running and could open security vulnerabilities. See https://go.microsoft.com/fwlink/?linkid=2173051 to learn more.
         A warning event occurred.  EventID: 0x80000023
            Event String:
            The Key Distribution Center (KDC) encountered a ticket-granting-ticket (TGT) from another KDC (SERVER2019DC2) that did not contain a PAC attributes field. See https://go.microsoft.com/fwlink/?linkid=2173051 to learn more.
            Time Generated: 08/07/2022   19:41:46
            Event String:
            The Kerberos client received a KRB_AP_ERR_MODIFIED error from the server server2019dc2$. The target name used was LDAP/c54ec21c-e264-4cb0-a5ca-4f370c223d22._msdcs.khayam.local. This indicates that the target server failed to decrypt the ticket provided by the client. This can occur when the target server principal name (SPN) is registered on an account other than the account the target service is using. Ensure that the target SPN is only registered on the account used by the server. This error can also happen if the target service account password is different than what is configured on the Kerberos Key Distribution Center for that target service. Ensure that the service on the server and the KDC are both configured to use the same password. If the server name is not fully qualified, and the target domain (KHAYAM.LOCAL) is different from the client domain (KHAYAM.LOCAL), check if there are identically named server accounts in these two domains, or use the fully-qualified name to identify the server.
         An error event occurred.  EventID: 0x40000005
            Event String:
            The Kerberos client received a KRB_AP_ERR_TKT_NYV error from the server server2019dc2$. This indicates that the ticket presented to that server is not yet valid (due to a discrepancy between ticket and server time. Contact your system administrator to make sure the client and server times are synchronized, and that the time for the Key Distribution Center Service (KDC) in realm KHAYAM.LOCAL is synchronized with the KDC in the client realm.
         ......................... SERVER-AC2012 failed test SystemLog
      Starting test: VerifyReferences
         ......................... SERVER-AC2012 passed test VerifyReferences
   Running partition tests on : ForestDnsZones
      Starting test: CheckSDRefDom
         ......................... ForestDnsZones passed test CheckSDRefDom
      Starting test: CrossRefValidation
         ......................... ForestDnsZones passed test CrossRefValidation
   Running partition tests on : DomainDnsZones
         ......................... DomainDnsZones passed test CheckSDRefDom
         ......................... DomainDnsZones passed test CrossRefValidation
   Running partition tests on : Schema
         ......................... Schema passed test CheckSDRefDom
         ......................... Schema passed test CrossRefValidation
   Running partition tests on : Configuration
         ......................... Configuration passed test CheckSDRefDom
         ......................... Configuration passed test CrossRefValidation
   Running partition tests on : khayam
         ......................... khayam passed test CheckSDRefDom
         ......................... khayam passed test CrossRefValidation
   Running enterprise tests on : khayam.local
      Starting test: LocatorCheck
         Warning: DcGetDcName(TIME_SERVER) call failed, error 1355
         A Time Server could not be located.
         The server holding the PDC role is down.
         Warning: DcGetDcName(GOOD_TIME_SERVER_PREFERRED) call failed, error 1355
         A Good Time Server could not be located.
         ......................... khayam.local failed test LocatorCheck
      Starting test: Intersite
         ......................... khayam.local passed test Intersite
پرسیده شده در 1401/05/16 توسط
چیزی که  log داره نشون میده چند تا مورد هستش که باید توجه بشه:
1- تعداد DC ها دو سرور هستش (server2016dc2 ,server2019dc2)
2-  DNS IP ادرس DC ها 8.8.8.8 هستش که باید 100% عوض بشه به IP ADDRESS خود DC یا (DC با DNS+INTEGRATED ZONE DOMAIN)
3- در نهایت بعد از تصحیح DNS سرور باید (AD DS service) یا سرور restart  بشه
4- replication بین سرورها چک بشه (repadmin)
5- اگر فقط یک DC هستش با دستور NETDOM  کامیپیوتر اکانت DC رو رست کن. در حین COMMAND از FQDN استفاده بشه
پاسخ در 1401/05/18 توسط
 Got error while checking LDAP and RPC connectivity. Please check your firewall settings.
         ......................... SERVER2016DC2 failed test Connectivity
         ......................... SERVER2019DC2 failed test Connectivity
         Warning: DsGetDcName returned information for \\server2019dc2.khayam.local, when we were trying to reach
         SERVER-AC2012.
         SERVER IS NOT RESPONDING or IS NOT CONSIDERED SUITABLE.
         [SERVER-AC2012] LDAP bind failed with error 8341. A directory service error has occurred.
         Unable to verify the machine account (CN=SERVER-AC2012,OU=Domain Controllers,DC=khayam,DC=local) for
         SERVER-AC2012 on SERVER2019DC2.
         [SERVER-AC2012] No security related replication errors were found on this DC!  To target the connection to a
         specific source DC use /ReplSource:<DC>.
         ** Did not run Outbound Secure Channels test because /testdomain: was not entered
            The failure occurred at 2022-08-08 22:32:17.
            19092 failures have occurred since the last success.
            19091 failures have occurred since the last success.
            19089 failures have occurred since the last success.
            AUTO_START
            NETLOGON Service is stopped on [SERVER-AC2012]
         An error event occurred.  EventID: 0xC00038D4
            Time Generated: 08/08/2022   22:02:53
            Event String:
            The DFS Namespace service could not initialize the trusted domain information on this domain controller, but it will periodically retry the operation. The return code is in the record data.
            Time Generated: 08/08/2022   22:03:59
            Event String:
            Time Generated: 08/08/2022   22:16:55
            Event String:
            Time Generated: 08/08/2022   22:22:30
            Event String:
            Time Generated: 08/08/2022   22:30:50
            Event String:
            The Kerberos client received a KRB_AP_ERR_MODIFIED error from the server server2019dc2$. The target name used was ldap/server2016dc2.khayam.local. This indicates that the target server failed to decrypt the ticket provided by the client. This can occur when the target server principal name (SPN) is registered on an account other than the account the target service is using. Ensure that the target SPN is only registered on the account used by the server. This error can also happen if the target service account password is different than what is configured on the Kerberos Key Distribution Center for that target service. Ensure that the service on the server and the KDC are both configured to use the same password. If the server name is not fully qualified, and the target domain (KHAYAM.LOCAL) is different from the client domain (KHAYAM.LOCAL), check if there are identically named server accounts in these two domains, or use the fully-qualified name to identify the server.
            Event String:
            Time Generated: 08/08/2022   22:30:52
            Event String:
            The Kerberos client received a KRB_AP_ERR_MODIFIED error from the server server2019dc2$. The target name used was cifs/SERVER2016DC2. This indicates that the target server failed to decrypt the ticket provided by the client. This can occur when the target server principal name (SPN) is registered on an account other than the account the target service is using. Ensure that the target SPN is only registered on the account used by the server. This error can also happen if the target service account password is different than what is configured on the Kerberos Key Distribution Center for that target service. Ensure that the service on the server and the KDC are both configured to use the same password. If the server name is not fully qualified, and the target domain (KHAYAM.LOCAL) is different from the client domain (KHAYAM.LOCAL), check if there are identically named server accounts in these two domains, or use the fully-qualified name to identify the server.
            Event String:
            The Kerberos client received a KRB_AP_ERR_MODIFIED error from the server server2019dc2$. The target name used was RPCSS/server2016dc2.khayam.local. This indicates that the target server failed to decrypt the ticket provided by the client. This can occur when the target server principal name (SPN) is registered on an account other than the account the target service is using. Ensure that the target SPN is only registered on the account used by the server. This error can also happen if the target service account password is different than what is configured on the Kerberos Key Distribution Center for that target service. Ensure that the service on the server and the KDC are both configured to use the same password. If the server name is not fully qualified, and the target domain (KHAYAM.LOCAL) is different from the client domain (KHAYAM.LOCAL), check if there are identically named server accounts in these two domains, or use the fully-qualified name to identify the server.
         An error event occurred.  EventID: 0x0000272C
            Event String:
            DCOM was unable to communicate with the computer server2016dc2.khayam.local using any of the configured protocols; requested by PID     26c4 (C:\WINDOWS\system32\dcdiag.exe), while activating CLSID {8BC3F05E-D86B-11D0-A075-00C04FB68820}.
            Event String:
            DCOM was unable to communicate with the computer server2019dc2.khayam.local using any of the configured protocols; requested by PID     26c4 (C:\WINDOWS\system32\dcdiag.exe), while activating CLSID {8BC3F05E-D86B-11D0-A075-00C04FB68820}.
            Time Generated: 08/08/2022   22:31:14
            Event String:
            DCOM was unable to communicate with the computer 8.8.8.8 using any of the configured protocols; requested by PID     26c4 (C:\WINDOWS\system32\dcdiag.exe), while activating CLSID {8BC3F05E-D86B-11D0-A075-00C04FB68820}.
            Time Generated: 08/08/2022   22:32:17
            Event String:
            DCOM was unable to communicate with the computer server2019dc2.khayam.local using any of the configured protocols; requested by PID     17cc (C:\WINDOWS\system32\dcdiag.exe), while activating CLSID {8BC3F05E-D86B-11D0-A075-00C04FB68820}.
            Event String:
            DCOM was unable to communicate with the computer server2016dc2.khayam.local using any of the configured protocols; requested by PID     17cc (C:\WINDOWS\system32\dcdiag.exe), while activating CLSID {8BC3F05E-D86B-11D0-A075-00C04FB68820}.
                           ......................... SERVER2019DC2 failed test DNS
                  ......................... SERVER2016DC2 failed test DNS
         Invalid service startup type: NETLOGON on SERVER-AC2012, current value DEMAND_START, expected value AUTO_START
         Test results for domain controllers:
            DC: SERVER-AC2012.khayam.local
            Domain: khayam.local
               TEST: Basic (Basc)
                  Error: NETLOGON service is not running
            TEST: Records registration (RReg)
               Error: Record registrations cannot be found for all the network adapters
            DC: server2016dc2.khayam.local
               TEST: Authentication (Auth)
                  Error: Authentication failed with specified credentials
               TEST: Basic (Basc)
                  Error: No LDAP connectivity
                  Error: No WMI connectivity
                  No host records (A or AAAA) were found for this DC
            DC: server2019dc2.khayam.local
               TEST: Basic (Basc)
         Summary of DNS test results:
                                            Auth Basc Forw Del  Dyn  RReg Ext
            _________________________________________________________________
               SERVER-AC2012                PASS FAIL PASS PASS PASS FAIL n/a
               server2016dc2                FAIL FAIL n/a  n/a  n/a  n/a  n/a
               server2019dc2                FAIL FAIL n/a  n/a  n/a  n/a  n/a
         ......................... khayam.local failed test DNS
         Warning: DcGetDcName(PDC_REQUIRED) call failed, error 1355
         A Primary Domain Controller could not be located.
         ......................... khayam.local failed test FsmoCheck
پاسخ در 1401/05/17 توسط
سلام ، لطفا خروجی دستور زیر رو ارسال کنید و بفرمایید که چند تا دامین کنترلر توی دامین تون دارید و سیستم عامل هاشون چی هست.
DCDIAG /c /v /e /q
دستور بالا فقط ارور ها رو نشون میده و تست هاش رو روی همه DC های اجرا می کنه و یه خروجی تمیز نشون میده. لطفا خروجی رو در قالب کد (پاراگراف -> بلوک ها -> کد) ارسال کنید تا خوندنش راحت تر هست. ممنونم
خروجی DCDIAG داره نشون میده که چند تا دامین کنترلر دارید (داشتید) ولی شما میگید که یدونه دامین کنترلر دارم - این میتونه به این معنی باشه که (البته خروجی DCDIAG هم اینو گواهی میده) اون دامین کنترلر ها از مدار خارج شدن اما نه بصورت درست. کاری که باید انجام بدید اینه که Metadata های باقی مونده از سایر دامین کنترلر ها رو از روی دامین کنترلری که روش DCDIAG رو اجرا کردید پاک کنید. لینک زیر رو ببینید :
https://servergurunow.wordpress.com/2017/08/08/metadata-cleanup-of-a-domain-controller-2
پیشنهاد می کنم از تو کنسول ADSI Edit هم object های مربوط به DC های قدیمی رو پاک کنید.
پ.ن : من گفتم خروجی DCDIAG رو در قالب کد (پاراگراف -> بلوک ها -> کد) ارسال کنید ولی این کار رو انجام ندادید.
پاسخ در 1401/05/21 توسط
سیستم عامل server2019
فقط یک عدد دومین کنترلر داره
