مشکل در عدم اتصال به سرور additional
ا سلام خدمت دوستان
متاسفانه سرور من مشکل عدم هماهنگی دارند
از روی هر کدوم از سرورها که میخام به اون یکی وصل بشم نمیتونم
در سرور دوم هم خطای مربوط به عدم دسترسی به اون سه تا رول دامین بیس رو میده
وقتی دستور dcdiag رو میزنم پیغام زیر رو میده
C:\Users\admin>dcdiag
Directory Server Diagnosis
Performing initial setup:
Trying to find home server...
Home Server = dc-backup
* Identified AD Forest.
Done gathering initial info.
Doing initial required tests
Testing server: Default-First-Site-Name\DC-BACKUP
Starting test: Connectivity
......................... DC-BACKUP passed test Connectivity
Doing primary tests
Starting test: Advertising
......................... DC-BACKUP passed test Advertising
Starting test: FrsEvent
There are warning or error events within the last 24 hours after the
SYSVOL has been shared. Failing SYSVOL replication problems may cause
Group Policy problems.
......................... DC-BACKUP passed test FrsEvent
Starting test: DFSREvent
......................... DC-BACKUP passed test DFSREvent
Starting test: SysVolCheck
......................... DC-BACKUP passed test SysVolCheck
Starting test: KccEvent
......................... DC-BACKUP passed test KccEvent
Starting test: KnowsOfRoleHolders
[VESAL-DC] DsBindWithSpnEx() failed with error 5,
Access is denied..
Warning: VESAL-DC is the PDC Owner, but is not responding to DS RPC
Bind.
[VESAL-DC] LDAP bind failed with error 1326,
Logon failure: unknown user name or bad password..
Warning: VESAL-DC is the PDC Owner, but is not responding to LDAP
Bind.
Warning: VESAL-DC is the Rid Owner, but is not responding to DS RPC
Bind.
Warning: VESAL-DC is the Rid Owner, but is not responding to LDAP
Bind.
Warning: VESAL-DC is the Infrastructure Update Owner, but is not
responding to DS RPC Bind.
responding to LDAP Bind.
......................... DC-BACKUP failed test KnowsOfRoleHolders
Starting test: MachineAccount
......................... DC-BACKUP passed test MachineAccount
Starting test: NCSecDesc
Error NT AUTHORITY\ENTERPRISE DOMAIN CONTROLLERS doesn't have
Replicating Directory Changes In Filtered Set
access rights for the naming context:
DC=vesal,DC=net
......................... DC-BACKUP failed test NCSecDesc
Starting test: NetLogons
[DC-BACKUP] User credentials does not have permission to perform this
operation.
The account used for this test must have network logon privileges
for this machine's domain.
......................... DC-BACKUP failed test NetLogons
Starting test: ObjectsReplicated
......................... DC-BACKUP passed test ObjectsReplicated
Starting test: Replications
......................... DC-BACKUP failed test Replications
Starting test: RidManager
......................... DC-BACKUP failed test RidManager
Starting test: Services
......................... DC-BACKUP passed test Services
Starting test: SystemLog
......................... DC-BACKUP passed test SystemLog
Starting test: VerifyReferences
......................... DC-BACKUP passed test VerifyReferences
Running partition tests on : DomainDnsZones
Starting test: CheckSDRefDom
......................... DomainDnsZones passed test CheckSDRefDom
Starting test: CrossRefValidation
CrossRefValidation
Running partition tests on : vesal
......................... vesal passed test CheckSDRefDom
......................... vesal passed test CrossRefValidation
Running partition tests on : ForestDnsZones
......................... ForestDnsZones passed test CheckSDRefDom
CrossRefValidation
Running partition tests on : Schema
......................... Schema passed test CheckSDRefDom
......................... Schema passed test CrossRefValidation
Running partition tests on : Configuration
......................... Configuration passed test CheckSDRefDom
......................... Configuration passed test CrossRefValidation
Running enterprise tests on : 3epad.net
Starting test: LocatorCheck
......................... 3epad.net passed test LocatorCheck
Starting test: Intersite
......................... 3epad.net passed test Intersite
پرسیده شده در 1394/04/20 توسط
مشکل فوق در سرویس rpc در سمت دامین اصلی بود
پاسخ در 1394/05/04 توسط
ببینید این کامندها می تونه کمک کنه متوجه مشکل بشید یا نه؟
برای خالی کردن cache دی ان اس سرور : C:\>ipconfig /flushdns چون ممکنه مشکل توی نگاشت های DNS server باشه.
استفاده از دستور ipconfig /registerdns برای ثبت اطلاعات نام کامپیوتر در dns سرور
و درنهایت هم کامند C:>repadmin /syncall برای اینکه تمامی replicate ها بین DC ها به یکباره انجام پذیردو به روزرسانی شود.
این ها رو روی هر دو سرور اجرا کنید
پاسخ در 1394/04/20 توسط
