مشکل در اکتیو دایرکتوری سرور2008
سلام وقت بخیر
من داخل شبکم یه سرور و additional server دارم ولی چند روز هست که روی رول active directory و dhcp روی سرورم علامت ضربدر قرمز زده و مشکلاتی هم داخل شبکه پیش اومد فقط بخاطر حضور additional serverشبکه و یوزرها سر پا هستند.
خواستم راهنماییم کنید آیا میشه این رول ها رو در سرور پاک کنم دوباره نصب کنم و با یه کاری دیتا های additional server به سرور انتقال پیدا کنه و شبکه ادامه کار بده و دوباره یوزر و اینها نسازیم؟؟؟
ممنون میشم کمکم کنید که چه میشه کرد؟؟
پرسیده شده در 1394/08/14 توسط
این کپی ارور هست
Log Name: Directory Service
Source: Microsoft-Windows-ActiveDirectory_DomainService
Date: 20151107 02:02:06 ب.ظ
Event ID: 2042
Task Category: Replication
Level: Error
Keywords: Classic
User: ANONYMOUS LOGON
Computer: server.hekmat.edu
Description:
It has been too long since this machine last replicated with the named source machine. The time between replications with this source has exceeded the tombstone lifetime. Replication has been stopped with this source.
The reason that replication is not allowed to continue is that the two DCs may contain lingering objects. Objects that have been deleted and garbage collected from an Active Directory Domain Services partition but still exist in the writable partitions of other DCs in the same domain, or read-only partitions of global catalog servers in other domains in the forest are known as "lingering objects". If the local destination DC was allowed to replicate with the source DC, these potential lingering object would be recreated in the local Active Directory Domain Services database.
Time of last successful replication:
2009-01-01 01:24:19
Invocation ID of source directory server:
e63f008a-a55d-43a6-a962-aac29821f88d
Name of source directory server:
7e0d4524-e5cb-40b1-bd39-9843cd60f1c7._msdcs.hekmat.edu
Tombstone lifetime (days):
180
The replication operation has failed.
User Action:
The action plan to recover from this error can be found at http://support.microsoft.com/?id=314282.
If both the source and destination DCs are Windows Server 2003 DCs, then install the support tools included on the installation CD. To see which objects would be deleted without actually performing the deletion run "repadmin removelingeringobjects &lt;Source DC&gt; &lt;Destination DC DSA GUID&gt; &lt;NC&gt; ADVISORY_MODE". The eventlogs on the source DC will enumerate all lingering objects. To remove lingering objects from a source domain controller run "repadmin /removelingeringobjects <Source DC> <Destination DC DSA GUID> <NC>".
If either source or destination DC is a Windows 2000 Server DC, then more information on how to remove lingering objects on the source DC can be found at http://support.microsoft.com/?id=314282 or from your Microsoft support personnel.
If you need Active Directory Domain Services replication to function immediately at all costs and don't have time to remove lingering objects, enable replication by setting the following registry key to a non-zero value:
Registry Key:
HKLM\System\CurrentControlSet\Services\NTDS\Parameters\Allow Replication With Divergent and Corrupt Partner
Replication errors between DCs sharing a common partition can prevent user and compter acounts, trust relationships, their passwords, security groups, security group memberships and other Active Directory Domain Services configuration data to vary between DCs, affecting the ability to log on, find objects of interest and perform other critical operations. These inconsistencies are resolved once replication errors are resolved. DCs that fail to inbound replicate deleted objects within tombstone lifetime number of days will remain inconsistent until lingering objects are manually removed by an administrator from each local DC. Additionally, replication may continue to be blocked after this registry key is set, depending on whether lingering objects are located immediately.
Alternate User Action:
Force demote or reinstall the DC(s) that were disconnected.
Event Xml:
<Event xmlns="http://schemas.microsoft.comwin200408events/event">
<System>
<Provider Name="Microsoft-Windows-ActiveDirectory_DomainService" Guid="{0e8478c5-3605-4e8c-8497-1e730c959516}" EventSourceName="NTDS General" />
<EventID Qualifiers="49152">2042</EventID>
<Version>0</Version>
<Level>2</Level>
<Task>5</Task>
<Opcode>0</Opcode>
<Keywords>0x8080000000000000</Keywords>
<TimeCreated SystemTime="2015-11-07T10:32:06.704589800Z" />
<EventRecordID>1239</EventRecordID>
<Correlation />
<Execution ProcessID="536" ThreadID="1860" />
<Channel>Directory Service</Channel>
<Computer>server.hekmat.edu</Computer>
<Security UserID="S-1-5-7" />
</System>
<EventData>
<Data>2009-01-01 01:24:19</Data>
<Data>e63f008a-a55d-43a6-a962-aac29821f88d</Data>
<Data>7e0d4524-e5cb-40b1-bd39-9843cd60f1c7._msdcs.hekmat.edu</Data>
<Data>180</Data>
<Data>Allow Replication With Divergent and Corrupt Partner</Data>
<Data>System\CurrentControlSet\Services\NTDS\Parameters</Data>
</EventData>
</Event>
پاسخ در 1394/08/16 توسط
چرا به فکر پاک کردن صورت مسئله هستید؟
پیام های خطا را بررسی کنید و نسبت به رفع آنها اقدام کنید.
1. از پیغام ها تصویری بگذارید.
2. Best Practice Analyzer را اجرا کنید، این ویژگی در رفع مشکلات به شما کمک زیادی خواهد کرد. از این قسمت نیز تصویری قرار دهید.
3. ساعت سرور ها، Replication بین آنها، Dns سرور های خود را چک کنید. اطمینان حاصل کنید که تمامی رکورد ها در Dns سرور شما ایجاد شده اند.
میتونی یه سرور دیگه بالا بیاری و اون به عنوان additional server راه اندازی کنی بعدش اونی که خرابه پاک کن
پاسخ در 1394/08/14 توسط
سلام همایون جان تشکر از جوابی که دادی. اما من additional server در شبکه دارم و سرور اصلی من دچار مشکل شده.
یعنی سرور اصلی رو پاک کنم؟ اونوقت دومین اصلی مشکل دار نمیشه؟؟ یعنی دوتا additional server داشته باشم و سرور رو پاک کنم؟
ضمن تشکر از جناب همایون بایستی یک مورد را یادآور بشم و اون هم این هستش که در شبکه های دومینی اولین Domain Controller همه رولهای پنجگانه FSMO را در اختیار دارد و Additional Server هیچکدام از اینها را ندارد و بنابراین در این سناریو اگر شما یک Additional Server دیگر راه اندازی کنید با این حساب شما DC از نوع Primary یا اصلی ندارید که FSMOها را داشته باشد و عملا امکانپذیر نمی باشد چون Additional DC ابتدا بایستی به یک join، Primary DC شود. پس قاعدتا یک PDC بجای DC خراب ایجاد کرد و FSMOها را درآن Seize کرد. از اساتید گرامی خواهش می کنم نسبت به ارایه نظر در این مورد دریغ نکنند. ضمن آنکه مشاهده لینک زیر خالی از لطف نیست.
پاسخ در 1394/08/15 توسط
