دلیل ارور 2886 اکتیو دایرکتوری و 4013 dns و راه حل رفع مشکل
سلام اکتیو دایرکتوری و dns من دو ارور 2886 و 4013 میده ، از دستور dcdiag تست سلامت گرفتم که به شرح زیر می باشد.لطفا کمکم کنید
  Testing server: Default-First-Site-Name\SERVER-PEDEC
      Starting test: Connectivity
         ......................... SERVER-PEDEC passed test Connec
Doing primary tests
      Starting test: Advertising
         ......................... SERVER-PEDEC passed test Advert
      Starting test: FrsEvent
         There are warning or error events within the last 24 hour
         SYSVOL has been shared.  Failing SYSVOL replication probl
         Group Policy problems.
         ......................... SERVER-PEDEC failed test FrsEve
      Starting test: DFSREvent
         ......................... SERVER-PEDEC passed test DFSREv
      Starting test: SysVolCheck
         ......................... SERVER-PEDEC passed test SysVol
      Starting test: KccEvent
         ......................... SERVER-PEDEC passed test KccEve
      Starting test: KnowsOfRoleHolders
         ......................... SERVER-PEDEC passed test KnowsO
      Starting test: MachineAccount
         ......................... SERVER-PEDEC passed test Machin
      Starting test: NCSecDesc
         Error NT AUTHORITY\ENTERPRISE DOMAIN CONTROLLERS doesn't
            Replicating Directory Changes In Filtered Set
         access rights for the naming context:
         DC=PEDEC,DC=com
         ......................... SERVER-PEDEC failed test NCSecD
      Starting test: NetLogons
         Unable to connect to the NETLOGON share! (\\SERVER-PEDEC         [SERVER-PEDEC] An net use or LsaPolicy operation failed w
         The network name cannot be found..
         ......................... SERVER-PEDEC failed test NetLog
      Starting test: ObjectsReplicated
         ......................... SERVER-PEDEC passed test Object
      Starting test: Replications
         ......................... SERVER-PEDEC passed test Replic
      Starting test: RidManager
         ......................... SERVER-PEDEC passed test RidMan
      Starting test: Services
         ......................... SERVER-PEDEC passed test Servic
      Starting test: SystemLog
         An error event occurred.  EventID: 0x00000422
            Time Generated: 09/01/2016   08:35:10
            Event String:
            The processing of Group Policy failed. Windows attempt
 file \\PEDEC.com\sysvol\PEDEC.com\Policies\{6AC1786C-016F-11D2-94
9}\gpt.ini from a domain controller and was not successful. Group
s may not be applied until this event is resolved. This issue may
nd could be caused by one or more of the following:
            Time Generated: 09/01/2016   08:40:11
            Event String:
            Time Generated: 09/01/2016   08:45:12
            Event String:
            Time Generated: 09/01/2016   08:50:12
            Event String:
            Time Generated: 09/01/2016   08:55:13
            Event String:
            Time Generated: 09/01/2016   09:00:14
            Event String:
         A warning event occurred.  EventID: 0x8000001D
            Time Generated: 09/01/2016   09:01:51
            Event String:
            The Key Distribution Center (KDC) cannot find a suitab
 to use for smart card logons, or the KDC certificate could not be
rt card logon may not function correctly if this problem is not re
rect this problem, either verify the existing KDC certificate usin
 or enroll for a new KDC certificate.
         A warning event occurred.  EventID: 0x800009CF
            Time Generated: 09/01/2016   09:01:56
            Event String:
            The server service was unable to recreate the share SY
he directory E:\Windows\SYSVOL\sysvol no longer exists.  Please ru
YSVOL /delete" to delete the share, or recreate the directory E:\W
sysvol.
            Event String:
            The server service was unable to recreate the share NE
 the directory E:\Windows\SYSVOL\sysvol\PEDEC.com\SCRIPTS no longe
ase run "net share NETLOGON /delete" to delete the share, or recre
ory E:\Windows\SYSVOL\sysvol\PEDEC.com\SCRIPTS.
         An error event occurred.  EventID: 0x0000164A
            Time Generated: 09/01/2016   09:02:06
            Event String:
            The Netlogon service could not create server share E:\sysvol.  The following error occurred:
            Event String:
            The Netlogon service could not create server share E:\sysvol\PEDEC.com\SCRIPTS.  The following error occurred:
         A warning event occurred.  EventID: 0x000003F6
            Time Generated: 09/01/2016   09:02:32
            Event String:
            Name resolution for the name _ldap._tcp.Default-First-
es.dc._msdcs.PEDEC.com timed out after none of the configured DNS
ded.
         An error event occurred.  EventID: 0xC00038D6
            Time Generated: 09/01/2016   09:02:36
            Event String:
            The DFS Namespace service could not initialize cross f
formation on this domain controller, but it will periodically retr
n. The return code is in the record data.
         A warning event occurred.  EventID: 0x0000000C
            Event String:
            Time Provider NtpClient: This machine is configured to
n hierarchy to determine its time source, but it is the AD PDC emu
domain at the root of the forest, so there is no machine above it
hierarchy to use as a time source. It is recommended that you eith
 reliable time service in the root domain, or manually configure t
ynchronize with an external time source. Otherwise, this machine w
s the authoritative time source in the domain hierarchy. If an ext
rce is not configured or used for this computer, you may choose to
tpClient.
            Time Generated: 09/01/2016   09:02:40
            Event String:
            Name resolution for the name _ldap._tcp.PEDEC.com time
ne of the configured DNS servers responded.
         A warning event occurred.  EventID: 0x000727AA
            Time Generated: 09/01/2016   09:05:08
            Event String:
            The WinRM service failed to create the following SPNs:
PEDEC.PEDEC.com; WSMAN/Server-PEDEC.
            Time Generated: 09/01/2016   09:05:46
            Event String:
            Time Generated: 09/01/2016   09:05:48
            Event String:
 file \\PEDEC.com\sysvol\PEDEC.com\Policies\{31B2F340-016D-11D2-94
         An error event occurred.  EventID: 0x00000457
            Time Generated: 09/01/2016   09:05:54
            Event String:
            Driver HP LaserJet M1530 MFP Series PCL 6 required for
.168.1.150!HP LaserJet M1530 MFP Series PCL 6 (Copy 1) is unknown.
dministrator to install the driver before you log in again.
            Time Generated: 09/01/2016   09:05:58
            Event String:
            Driver Nitro Reader Driver 3 required for printer Nitr
(Reader 3) is unknown. Contact the administrator to install the dr
u log in again.
            Event String:
            Driver Send to Microsoft OneNote 15 Driver required fo
 To OneNote 2013 is unknown. Contact the administrator to install
            Event String:
serJet M1530 MFP Series PCL 6 is unknown. Contact the administrato
            Time Generated: 09/01/2016   09:05:59
            Event String:
            Driver Master PDF Editor 3.0.0.0 required for printer
tor 3 is unknown. Contact the administrator to install the driver
 in again.
            Event String:
            Driver Foxit Reader PDF Printer Driver required for pr
ader PDF Printer is unknown. Contact the administrator to install
            Event String:
            Driver zvprt1 required for printer GAMPrinter is unkno
e administrator to install the driver before you log in again.
            Time Generated: 09/01/2016   09:10:47
            Event String:
            Time Generated: 09/01/2016   09:15:48
            Event String:
            Time Generated: 09/01/2016   09:20:48
            Event String:
            Time Generated: 09/01/2016   09:25:49
            Event String:
            Time Generated: 09/01/2016   09:30:49
            Event String:
         ......................... SERVER-PEDEC failed test System
      Starting test: VerifyReferences
         ......................... SERVER-PEDEC passed test Verify
   Running partition tests on : ForestDnsZones
      Starting test: CheckSDRefDom
         ......................... ForestDnsZones passed test Chec
      Starting test: CrossRefValidation
         CrossRefValidation
   Running partition tests on : DomainDnsZones
         ......................... DomainDnsZones passed test Chec
         CrossRefValidation
   Running partition tests on : Schema
         ......................... Schema passed test CheckSDRefDo
         ......................... Schema passed test CrossRefVali
   Running partition tests on : Configuration
         ......................... Configuration passed test Check
         ......................... Configuration passed test Cross
   Running partition tests on : PEDEC
         ......................... PEDEC passed test CheckSDRefDom
         ......................... PEDEC passed test CrossRefValid
   Running enterprise tests on : PEDEC.com
      Starting test: LocatorCheck
         ......................... PEDEC.com passed test LocatorCh
      Starting test: Intersite
         ......................... PEDEC.com passed test Intersite
پرسیده شده در 1395/06/11 توسط
ITPRO ی عزیز خطای 4013 سرویس DNS شاید بدترین خطایی باشه که ممکنه رخ بده چون دلایل بسیار زیادی برای مشکلش وجود داره ، من چند پیشنهاد میدم خدمتتون اجرا کنید و در صورتیکه مشکل هنوز سرجاش بود ادامه موارد رو بررسی می کنیم ، ابتدا کلیه Log های موجود در Event Viewer رو حذف کنید تا پاک پاک بشه و dcdaig از لاگهای قدیمی برای خروجی جدید استفاده نکنه ، نرم افزار Ccleaner رو نصب کنید و همه تیکهاش رو بزنید و بگذارید سیستم رو به کلی تمیز بکنه ، بعد مجددا Event Viewer رو پاک کنید ، خوب وارد DNS بشید و بررسی کنید Name Server های شما به آدرسهای درستی اشاره می کنند ، مطمئن بشید که هیچ DC ای در DNS و Sites and Services وجود نداره که معدوم باشه و از قبل وجود داشته باشه ، اگر دو تا DC دارید آدرسهای DNS رو بصورت ضربدری قرار بدید ، یکبار سرورهاتون رو Restart کنید بصورت غیرهمزمان و بعد تلاش کنید تست بگیرید ... امیدوارم مشکل حل بشه ...
