مشکل در راه اندازی Bind DNS Server
با سلام و احترام
بنده برای راه اندازی GEO DNS Server بوسیله bind9 بر روی سرور Ubuntu به نحو زیر عمل کردم .
1 - نصب bind9
2 - تغییر فایل :
sudo vi etcdefault/bind9
# run resolvconf?
RESOLVCONF=no
# startup options for the server
OPTIONS="-4 -u bind"
3 - تغییر فایل :
etcbind/named.conf.options
acl "trusted" {
        192.168.1.88/29;    # Test
options {
        directory "/var/cache/bind";
        recursion yes;                 # enables resursive queries
        allow-recursion { trusted; };  # allows recursive queries from "trusted" clients
        listen-on { 192.168.1.93; };   # ns1 private IP address - listen on private network only
        allow-transfer { none; };      # disable zone transfers by default
        forwarders {
                8.8.8.8;
                8.8.4.4;
        // to talk to, you may need to fix the firewall to allow multiple
        // ports to talk.  See http://www.kb.cert.org/vuls/id/800113
        // If your ISP provided one or more IP addresses for stable
        // nameservers, you probably want to use them as forwarders.
        // Uncomment the following block, and insert the addresses replacing
        // the all-0's placeholder.
        // forwarders {
        //      0.0.0.0;
        // If BIND logs error messages about the root key being expired,
        // you will need to update your keys.  See https://www.isc.org/bind-keys
        dnssec-validation auto;
        auth-nxdomain no;    # conform to RFC1035
        listen-on-v6 { any; };
4 - ساخت فایل zone به شکل زیر
A : db.example.local
$TTL    604800
@       IN      SOA     example.local. admin.example.local. (
                  3       ; Serial
             604800     ; Refresh
              86400     ; Retry
            2419200     ; Expire
             604800 )   ; Negative Cache TTL
; name servers - NS records
     IN      NS      example.local.
; name servers - A records
example.local.          IN      A       192.168.1.93
; 193.178.201.88/29 - A records
host1.example.local.        IN      A      192.168.1.91
host2.example.local.        IN      A      192.168.1.94
test.example.local.        IN      A      192.168.1.95
B:db.example.test
$TTL    604800
                  3       ; Serial
             604800     ; Refresh
              86400     ; Retry
            2419200     ; Expire
test.example.local.        IN      A      192.168.1.92
C:cat db.192.168.1
$TTL    604800
                              5         ; Serial
                         604800         ; Refresh
                          86400         ; Retry
                        2419200         ; Expire
; name servers
1.168.192.in-addr.arpa     IN      NS      example.local.
; PTR Records
93   IN      PTR     example.local.    ; 192.168.1.93
91   IN      PTR     host1.example.local.    ; 192.168.1.91
94 IN      PTR     host2.example.local.  ; 192.168.1.94
95 IN      PTR     test.example.local.  ; 192.168.1.95
91 IN      PTR     test.example.local.  ; 192.168.1.91
5 - ویرایش فایل :
named.conf.default-zones
view "Iran" {
  match-clients { 192.168.1.91; };
  zone "chavoosh.local" {
    file "/etc/bind/zones/db.example.local";
    type master;
  zone "1.168.192.in-addr.arpa" {
    type master;
    file "/etc/bind/zones/db.192.168.1";  # 192.168.1.0/24 subnet
view "USA" {
  match-clients { 192.168.1.94; };
    file "/etc/bind/zones/db.example.test";
    type master;
    type master;
در ادامه با دستورات زیر کانفیگ را چک کردم و خطایی بر روی تنظیمات دریافت نکردم .
sudo named-checkconf
sudo named-checkzone example.local db.example.local
sudo named-checkzone example.local db.example.test
sudo named-checkzone 1.168.192.in-addr.arpa etcbindzonesdb.192.168.1
و سرویس را ریستارت میکنم .
حالا از روی یک کلاینت دستور nslookup را میگیرم نام دامین DNS Server را نمیاره ولی توی تبدیل نام به IP درست عمل میکنه و وقتی من آدرس کلاینتم را عوض می کنم ، آدرس IP اعلامی برای test.example.local نیز طبق آنچه در view تعریف کردم تغییر میکند.
ولی مشکل با ترجمه IP به نام هست که نمیتونه !
دوستان اگه راهنمایی در مورد تنظیمات بنده و چگونگی تصحیح Reverse DNS و مشکلی که هست دارند ممنون میشم در اختیار اینجانب بزارند .
منبع آموزشی کاملی هم در این بابا هست لطف کنید معرفی کنید . چون من این تنظیمات را طبق راه نمایی های چند سایت انجام دادم و به این نتیجه رسیدم .
پرسیده شده در 1395/07/26 توسط
فکر می کنم مشکل توی تعاریفم بود .
یک بار دیگه پروژه را جلو رفتم و همه مشکلات حل شد .
البته با یک رنج دیگه امتحان کردم .
10.128.0.0/16
پاسخ در 1395/07/28 توسط
