DPM (data protection manager
آموزش کار با نرم افزار DPM برای ویندوز سرور 2012 رو در صورت امکان قرار دهید
پرسیده شده در 1395/08/27 توسط
DPM is the best backup solution for the Windows Platform. Period! DPM allows you to backup File Servers (even open files!), that’s easy, but it also allows you to backup Exchange Servers, SQL Servers, SharePoint Servers, Virtualized workloads, and desktops! DPM can even back up your mobile desktops.
Not only does it allow you to intelligently backup these workloads, but it does all of this without creating an outage to take these backups. DPM will make backups of your Exchange Servers, SQL Servers, SharePoint Servers, Virtualized workloads, File Servers, and desktops in real time without user interruption! Take note: virtualized workloads can be backed up in real time as long as the guest OS is VSS aware (Volume Snapshot Service). VSS is included in Windows Server 2003, Windows Server 2008 (and R2) as well as the Client OS’, Windows XP, Windows Vista, and Windows 7. These virtualized versions of Windows can be backed up in real time. Keep in mind that the Windows Client OS’ are the professional SKUs only. The home use SKU’s are not supported in a virtual environment.
پاسخ در 1396/08/30 توسط
چرا کسی جواب نمیده؟ جایی سراغ دارین آموزش DPM رو؟
پاسخ در 1395/09/03 توسط
پست خوبیه من هم موافقم توی آی تی پرو این نوع آموزش را قرار بدن بهترین پروداکت بکاپ گیری و رستور برای سیستم عاملهاست مرسی از این پستتون
پاسخ در 1395/08/27 توسط
