جشنواره تخفیف های روز پدر! تا ۹۰٪ تخفیف! جشنواره تخفیف های روز پدر! تا ۹۰٪ تخفیف!
مشکل در ارسال ایمیل توسط mdeamon
سلام ، چند روز هست میل سرور ایمیل ارسال نمی کنه و این خطا را می دهد :
=  Greetings from the MDaemon mail system at   =
The following message:
     Session-ID: 907256 (specific to this delivery attempt)
       Queue-ID: pd35002877031.msg
     Message-ID: WC20171214194700.00000C@r
could not be delivered to the following recipient(s):
     t.m3744@gmail.com (unrecoverable error)
despite one or more unsuccessful attempts to do so.
No further delivery attempts will be made and the message has been removed from the queue.
The original message headers follow at the end of this report.  For information on DSN messages see http://www.altn.com/dsn/.
Please quote the Queue-ID, Session-ID, and Message-ID found above in any inquiries regarding this message.
=  Session Transcript  =
  Session 907256; child 0001
  Parsing message <xxxxxxxxxxxxxxxxxxxxxxxx\pd35002877031.msg>
  *  To: t.m3744@gmail.com
  *  Subject: Re: VPN -mt960923
  *  Size (bytes): 28796
  *  Message-ID: <WC20171214194700.00000C@a>
  Resolving MX record for gmail.com (DNS Server: IP)...
  *  P=005 S=003 D=gmail.com TTL=(9) MX=[gmail-smtp-in.l.google.com]
  *  P=010 S=001 D=gmail.com TTL=(9) MX=[alt1.gmail-smtp-in.l.google.com]
  *  P=020 S=004 D=gmail.com TTL=(9) MX=[alt2.gmail-smtp-in.l.google.com]
  *  P=030 S=002 D=gmail.com TTL=(9) MX=[alt3.gmail-smtp-in.l.google.com]
  *  P=040 S=000 D=gmail.com TTL=(9) MX=[alt4.gmail-smtp-in.l.google.com]
  Attempting SMTP connection to gmail-smtp-in.l.google.com
  Resolving A record for gmail-smtp-in.l.google.com (DNS Server)...
  *  D=gmail-smtp-in.l.google.com TTL=(3) A=[IP]
  Attempting SMTP connection to IP
  Waiting for socket connection...
  *  Connection established IP:50669 --> IP:25
  Waiting for protocol to start...
  <-- 220 mx.google.com ESMTP w134si3471477wmd.253 - gsmtp
  --> EHLO m
  <-- 250-mx.google.com at your service, [IP]
  <-- 250-SIZE 157286400
  <-- 250-8BITMIME
  <-- 250-STARTTLS
  <-- 250-ENHANCEDSTATUSCODES
  <-- 250-PIPELINING
  <-- 250-CHUNKING
  <-- 250 SMTPUTF8
  --> MAIL From:<aaaaaaaaaa@dums.ac.ir> SIZE=28796
  <-- 250 2.1.0 OK w134si3471477wmd.253 - gsmtp
  --> RCPT To:<t.m3744@gmail.com>
  <-- 250 2.1.5 OK w134si3471477wmd.253 - gsmtp
  --> DATA
  <-- 354  Go ahead w134si3471477wmd.253 - gsmtp
  Sending <xxxxxxxxxxxxxxxxxxxxxxxx\pd35002877031.msg> to [173.194.76.26]
  Transfer Complete
  <-- 550-5.7.1 [IP     12] Our system has detected that this message is
  <-- 550-5.7.1 likely unsolicited mail. To reduce the amount of spam sent to Gmail,
  <-- 550-5.7.1 this message has been blocked. Please visit
  <-- 550-5.7.1  https://support.google.com/mail/?p=UnsolicitedMessageError
  <-- 550 5.7.1  for more information. w134si3471477wmd.253 - gsmtp
  --> QUIT
=    End Transcript    =
Reporting-MTA: dns;
Received-From-MTA: dns; WorldClient
Arrival-Date: Thu, 14 Dec 2017 23:17:01 +0330
X-MDaemon-Version: 16.5.1
Final-Recipient: rfc822; t.m3744@gmail.com
Last-Attempt-Date: Thu, 14 Dec 2017 23:17:04 +0330
Remote-MTA: dns; gmail-smtp-in.l.google.com
Diagnostic-Code: smtp; 550 5.7.1  for more information. w134si3471477wmd.253 - gsmtp
Status: 5.7.1
Action: failed
پرسیده شده در 1396/09/24 توسط
به لینکی که تو log هست مراجعه کنید ببینید بر اساس error number خطا چیه ؟ البته ممکنه خیلی دقیق نگه
<-- 550-5.7.1 |https:/support.google.com/mail?p=UnsolicitedMessageError
پاسخ در 1396/09/24 توسط
مشخصا تو black list رفتین
به mxtoolbox.com برین و IP Backlist رو چک کنید
