قطع شدن تمامی دسترسی ها
سلام و عرض ادب خدمت اساتید بزورگوار
ی سوال داشتم خدمتتون
در شبکه ما متاسفانه با قطع شدن اینترنت، کلیه دسترسی ها بسته خواهد شد
یعنی اگر اینترنت اصلی که از ISP به روتربورد میکروتیک وصل هست قطع بشه
1- مپ درایوها کلا قطع خواهد شد
2- نمی توان به ویندوز لاگین شد
پرسیده شده در 1399/01/14 توسط
11 پاسخ
بله شبکه دامین هستش ،
ببخشید،
  • Microsoft Windows [Version 6.3.9600]
    (c) 2013 Microsoft Corporation. All rights reserved.
    C:\Windows\system32>GPResult /r
    Microsoft (R) Windows (R) Operating System Group Policy Result tool v2.0
    c 2013 Microsoft Corporation. All rights reserved.
    Created on 4/6/2020 at 6:40:57 PM
    RSOP data for BA\B.Amani on ARAM: Logging Mode
    OS Configuration:            Additional/Backup Domain Controller
    OS Version:                  6.3.9600
    Site Name:                   BA
    Roaming Profile:             N/A
    Local Profile:               C:\Users\B.Amani
    Connected over a slow link?: Yes
    COMPUTER SETTINGS
        CN=ARAM,OU=Domain Controllers,DC=BA,DC=vg,DC=local
        Last time Group Policy was applied: 4/6/2020 at 6:37:26 PM
        Group Policy was applied from:      BA.local
        Group Policy slow link threshold:   500 kbps
        Domain Name:                        BA
        Domain Type:                        Windows 2008 or later
        Applied Group Policy Objects
            Default Domain Controllers Policy
            Default Domain Policy
        The following GPOs were not applied because they were filtered out
            Local Group Policy
                Filtering:  Not Applied (Empty)
        The computer is a part of the following security groups
            BUILTIN\Administrators
            Everyone
            BUILTIN\Pre-Windows 2000 Compatible Access
            BUILTIN\Users
            Windows Authorization Access Group
            NT AUTHORITY\NETWORK
            NT AUTHORITY\Authenticated Users
            This Organization
            BA$
            Domain Controllers
            NT AUTHORITY\ENTERPRISE DOMAIN CONTROLLERS
            Authentication authority asserted identity
            Denied RODC Password Replication Group
            System Mandatory Level
    USER SETTINGS
        CN=Bahram Amani,OU=BA_User's,DC=BA,DC=vg,DC=local
        Last time Group Policy was applied: 4/6/2020 at 5:47:25 PM
        Domain Name:                        BA
            Local Group Policy
        The user is a part of the following security groups
            Domain Users
            Everyone
            BUILTIN\Users
            REMOTE INTERACTIVE LOGON
            NT AUTHORITY\INTERACTIVE
            This Organization
            LOCAL
            Domain Admins
            High Mandatory Level
پاسخ در 1399/01/18 توسط
تو دامین کنترلر وارد کنسول GPMC بشید و Default Domain Policy رو چک کنید ببینید مقدار پالسی Interactive Logon:Number of previous logons to cache تو مسیر زیر به صفر تنظیم نشده ؟
Computer Configuration\Windows Settings\Security Settings\Local Policies\Security Options
دستور زیر رو اجرا کنید تا کش offline files خالی بشه بعد مجددا تست کنید ببینید وقتی اینترنت قطع میشه یوزر ها باز هم نمیتونن Map drive رو باز کنن :
REG ADD "HKLM\System\CurrentControlSet\Services\CSC\Parameters" /v FormatDatabase /t REG_DWORD /d 1 /f
سلام و روز بخیر، جناب کریم پور ممنون بابت الطافتون
مهندس پالسی صفر نیست !!!
در ضمن با دستوری که فرمودین کش هم پاک شد، اما متاسفانه مشکل کماکان برقرار می باشد !!!!!!!
پاسخ در 1399/01/19 توسط
سلام ، چک کنید ببینید توی میکروتیک تون VPN Tunnel ای چیزی زده شده به یه شبکه دیگه ؟
پاسخ در 1399/01/14 توسط
دوست عزیز باز که Local Group Policy رو باز کردید !!! توی DC تو RUN تایپ کنید gpmc.msc و اینتر رو بزنید. و Default Domain Policy رو چک کنید.
Local Group Policy رو نباید چک کنید اگه شبکه دامین هست. خروجی دستور GPResult /r رو لطفا ارسال کنید. دستور رو روی کلاینت و با دسترسی ادمین اجرا کنید. خروجی رو لطفا در قالب code box ارسال کنید تا خوندنش راحت تر باشه. ممنونم
میتونید مشکل قطع شدن دسترسی کلاینت ها به Map drive رو در زمان قطع شدن اینترنت با فعال کردن قابلیت Offline files برطرف کنید. اینکه یوزر ها بعد از قطعی اینترنت نمیتونن به سیستم هاشون لاگین کنن نشون دهنده اینه که پالسی Interactive Logon:Number of previous logons to cache براشون فعال شده و مقدار صفر براش ست شده که به این معنی هست که یوزر ها فقط و فقط بتونن در زمان آنلاین بودن دامین کنترلر به سیستم لاگین کنن. به صورت یش فرض اگه اشتباه نکنم تا 10 بار میتونن به سیستم لاگین کن و بار 11 ام باید توسط DC احرازهویت بشن. من زیاد پیشنهاد نمی کنم که رفتار لاگین کلاینت ها رو تغییر بدید. بزارید با Cache خودشون لاگین کنن اینجوری بهتره.
مهندس عزیز این قابلیت هم فعال می باشد
سلام، ممنونم از لطفتون
بله  VPN Tunnel داریم.
جناب کریم پور ضمن تشکر بابت لطفتون
این قابلیت به صورت پیش فرض می باشد
Group policy
