راهنمایی در مورد load balancing توسط روتر میکروتیک
سلام از این اسکریپت استفاده کردم که دو خط اینترنتم را بالانس کنم در شبکه اداره اما نشد ،ادرس لینک اصلی اسکریپت :
Mikrotik DUAL WAN Load Balancing using PCC method. Complete Script ! by zaiB
کدها :
/ip address
add address=192.168.0.1/24 network=192.168.0.0 broadcast=192.168.0.255 interface=Local
add address=192.168.1.2/24 network=192.168.1.0 broadcast=192.168.1.255 interface=WAN1
add address=192.168.2.2/24 network=192.168.2.0 broadcast=192.168.2.255 interface=WAN2
/ip dns set allow-remote-requests=yes cache-max-ttl=1w cache-size=5000KiB max-udp-packet-size=512 servers=221.132.112.8,8.8.8.8
/ip firewall mangle
add chain=input in-interface=WAN1 action=mark-connection new-connection-mark=WAN1_conn
add chain=input in-interface=WAN2 action=mark-connection new-connection-mark=WAN2_conn
add chain=output connection-mark=WAN1_conn action=mark-routing new-routing-mark=to_WAN1
add chain=output connection-mark=WAN2_conn action=mark-routing new-routing-mark=to_WAN2
add chain=prerouting dst-address=192.168.1.0/24 action=accept in-interface=Local
add chain=prerouting dst-address=192.168.2.0/24 action=accept in-interface=Local
add chain=prerouting dst-address-type=!local in-interface=Local per-connection-classifier=both-addresses-and-ports:2/0 action=mark-connection new-connection-mark=WAN1_conn passthrough=yes
add chain=prerouting dst-address-type=!local in-interface=Local per-connection-classifier=both-addresses-and-ports:2/1 action=mark-connection new-connection-mark=WAN2_conn passthrough=yes
add chain=prerouting connection-mark=WAN1_conn in-interface=Local action=mark-routing new-routing-mark=to_WAN1
add chain=prerouting connection-mark=WAN2_conn in-interface=Local action=mark-routing new-routing-mark=to_WAN2
/ip route
add dst-address=0.0.0.0/0 gateway=192.168.1.1 routing-mark=to_WAN1 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=192.168.2.1 routing-mark=to_WAN2 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=192.168.1.1 distance=1 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=192.168.2.1 distance=2 check-gateway=ping
/ip firewall nat
add chain=srcnat out-interface=WAN1 action=masquerade
add chain=srcnat out-interface=WAN2 action=masquerade
فیلم از بالانس نبودن خطوط اینترنت شبکه خودم با توجه به دستورات بالا :
http://www.uplooder.net/cgi-bin/dl.cgi?key=9831a29880e158bb1a2729157c94006e
کسی انجام داده بتونه کامل خطوط اینترنت را داخل شبکه بالانس کنه و بتونه نهایت سرعت را از دو خط بگیره ؟
پرسیده شده در 1394/04/01 توسط
خوب حالا برای کاری که من می خواهم انجام بدم راه حلی دارید
پاسخ در 1394/04/03 توسط
اگه میخوای حرفه ای Load balance کنید یا باید سراغ سیسکو برین ، یا دستگاههای مخصوص بالانسینگ مثل pplink که کارایی بالایی داره /
من فکر کنم این بیشتر جنبه Fail over داشته باشه ، که هنگامی که یکی از کانکشن ها قطع بشه روی اون یکی سوئئچ کنه
تازه اینم به شرطی که ISP شما بعد این که مثلا اینترنتتون قطع شد ، کانکشن ppoe رو قطع کنه و cash server خودشو نشونتون نده ، چون اینجور میکروتیک متوجه قطعی نمیشه /
پاسخ در 1394/04/02 توسط
