بالانس چهار خط در میکروتیک
سلام این اموزش تو نت پیدا کردم ولی متاسفانه عملی نشود مشکل کجاست
چون خیلی ها میگردن دنبال اموزش این روش شاید مشکل اونها هم حل بشه
/ip address
add address=192.168.0.1/24 network=192.168.0.0 broadcast=192.168.0.255 interface=Local
add address=192.168.1.2/24 network=192.168.1.0 broadcast=192.168.1.255 interface=WAN1
add address=192.168.2.2/24 network=192.168.2.0 broadcast=192.168.2.255 interface=WAN2
add address=192.168.3.2/24 network=192.168.3.0 broadcast=192.168.3.255 interface=WAN3
add address=192.168.4.2/24 network=192.168.4.0 broadcast=192.168.4.255 interface=WAN4
/ip firewall mangle
add chain=input in-interface=WAN1 action=mark-connection new-connection-mark=WAN1_conn
add chain=input in-interface=WAN2 action=mark-connection new-connection-mark=WAN2_conn
add chain=input in-interface=WAN3 action=mark-connection new-connection-mark=WAN3_conn
add chain=input in-interface=WAN4 action=mark-connection new-connection-mark=WAN4_conn
add chain=output connection-mark=WAN1_conn action=mark-routing new-routing-mark=to_WAN1
add chain=output connection-mark=WAN2_conn action=mark-routing new-routing-mark=to_WAN2
add chain=output connection-mark=WAN3_conn action=mark-routing new-routing-mark=to_WAN3
add chain=output connection-mark=WAN4_conn action=mark-routing new-routing-mark=to_WAN4
add chain=prerouting dst-address=192.168.1.0/24 action=accept in-interface=Local
add chain=prerouting dst-address=192.168.2.0/24 action=accept in-interface=Local
add chain=prerouting dst-address=192.168.3.0/24 action=accept in-interface=Local
add chain=prerouting dst-address=192.168.4.0/24 action=accept in-interface=Local
add chain=prerouting dst-address-type=!local in-interface=Local per-connection-classifier=both-addresses-and-ports:4/0 action=mark-connection new-connection-mark=WAN1_conn passthrough=yes
add chain=prerouting dst-address-type=!local in-interface=Local per-connection-classifier=both-addresses-and-ports:4/1 action=mark-connection new-connection-mark=WAN2_conn passthrough=yes
add chain=prerouting dst-address-type=!local in-interface=Local per-connection-classifier=both-addresses-and-ports:4/2 action=mark-connection new-connection-mark=WAN3_conn passthrough=yes
add chain=prerouting dst-address-type=!local in-interface=Local per-connection-classifier=both-addresses-and-ports:4/3 action=mark-connection new-connection-mark=WAN4_conn passthrough=yes
add chain=prerouting connection-mark=WAN1_conn in-interface=Local action=mark-routing new-routing-mark=to_WAN1
add chain=prerouting connection-mark=WAN2_conn in-interface=Local action=mark-routing new-routing-mark=to_WAN2
add chain=prerouting connection-mark=WAN3_conn in-interface=Local action=mark-routing new-routing-mark=to_WAN3
add chain=prerouting connection-mark=WAN4_conn in-interface=Local action=mark-routing new-routing-mark=to_WAN4
/ip route
add dst-address=0.0.0.0/0 gateway=192.168.1.1 routing-mark=to_WAN1 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=192.168.2.1 routing-mark=to_WAN2 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=192.168.3.1 routing-mark=to_WAN3 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=192.168.4.1 routing-mark=to_WAN4 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=192.168.1.1 distance=1 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=192.168.2.1 distance=2 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=192.168.3.1 distance=3 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=192.168.4.1 distance=4 check-gateway=ping
/ip firewall nat
add chain=srcnat out-interface=WAN1 action=masquerade
add chain=srcnat out-interface=WAN2 action=masquerade
add chain=srcnat out-interface=WAN3 action=masquerade
add chain=srcnat out-interface=WAN4 action=masquerade
Now Configure DNS server so users can resolve hostnames,
/ip dns set allow-remote-requests=yes cache-max-ttl=1w cache-size=5000KiB max-udp-packet-size=512 servers=221.132.112.8,8.8.8.8
PCC WITH UN-EQUAL WAN LINKS
If you have Un-Equal WAN Links, for example WAN,1,2,3 are of 4MB and WAN,4 is of 8 Mb, and you want to force MT to use WAN4 link more then other because of its capacity, Then you have to Add more PCC rules assigning the same two marks to a specific link i.e WAN4 , something like
add chain=prerouting dst-address-type=!local in-interface=Local per-connection-classifier=both-addresses-and-ports:4/4 action=mark-connection new-connection-mark=WAN4_conn passthrough=yes
Try defining the outbound interface.
For example replace this.
/ip route
 add dst-address=0.0.0.0/0 gateway=1.2.3.4 routing-mark=to_wan-ISP1 check-gateway=ping
 add dst-address=0.0.0.0/0 gateway=1.2.3.4 routing-mark=to_wan-ISP2 check-gateway=ping
With following
/ip route
 add dst-address=0.0.0.0/0 gateway=1.2.3.4%eth1-ISP routing-mark=to_wan-ISP1 check-gateway=ping
 add dst-address=0.0.0.0/0 gateway=1.2.3.4%eth2-ISP routing-mark=to_wan-ISP2 check-gateway=ping
پرسیده شده در 1396/01/18 توسط
از کدوم مرجع این آموزش رو گرفتید؟
پاسخ در 1396/01/19 توسط
https://aacable.wordpress.com/
https://forum.mikrotik.com/viewtopic.php?t=100029
