مشکل در اتصال دامنه و تنظیمات BIND
سلام وقت بخیر
من توی تنظیم دامنه و تنظیمات BIND به مشکل خوردم و هنگام برسی استاتوس BIND این پیغام نمایش داده میشه
systemctl status named -l
● named.service - Berkeley Internet Name Domain (DNS)
   Loaded: loaded (/usr/lib/systemd/system/named.service; enabled; vendor preset: disabled)
   Active: active (running) since Sun 2020-05-31 13:22:55 EDT; 25s ago
  Process: 3378 ExecStop=/bin/sh -c /usr/sbin/rndc stop > /dev/null 2>&1 || /bin/kill -TERM $MAINPID (code=exited, status=0/SUCCESS)
  Process: 3392 ExecStart=/usr/sbin/named -u named -c ${NAMEDCONF} $OPTIONS (code=exited, status=0/SUCCESS)
  Process: 3389 ExecStartPre=/bin/bash -c if [ ! "$DISABLE_ZONE_CHECKING" == "yes" ]; then /usr/sbin/named-checkconf -z "$NAMEDCONF"; else echo "Checking of zone files is disabled"; fi (code=exited, status=0/SUCCESS)
 Main PID: 3394 (named)
   CGroup: /system.slice/named.service
           └─3394 /usr/sbin/named -u named -c /etc/named.conf
May 31 13:22:55 sentora.kahrobabot.ir named[3394]: network unreachable resolving './DNSKEY/IN': 2001:dc3::35#53
May 31 13:22:55 sentora.kahrobabot.ir named[3394]: network unreachable resolving './NS/IN': 2001:dc3::35#53
May 31 13:22:55 sentora.kahrobabot.ir named[3394]: network unreachable resolving './DNSKEY/IN': 2001:500:2::c#53
May 31 13:22:55 sentora.kahrobabot.ir named[3394]: network unreachable resolving './NS/IN': 2001:500:2::c#53
May 31 13:22:55 sentora.kahrobabot.ir named[3394]: network unreachable resolving './DNSKEY/IN': 2001:7fd::1#53
May 31 13:22:55 sentora.kahrobabot.ir named[3394]: network unreachable resolving './NS/IN': 2001:7fd::1#53
May 31 13:22:55 sentora.kahrobabot.ir named[3394]: network unreachable resolving './DNSKEY/IN': 2001:500:2f::f#53
May 31 13:22:55 sentora.kahrobabot.ir named[3394]: network unreachable resolving './NS/IN': 2001:500:2f::f#53
May 31 13:22:55 sentora.kahrobabot.ir named[3394]: managed-keys-zone: Key 20326 for zone . acceptance timer complete: key now trusted
May 31 13:22:55 sentora.kahrobabot.ir named[3394]: resolver priming query complete
تنظیمات فایل named هم به این صورت هستش
// named.conf
// Provided by Red Hat bind package to configure the ISC BIND named(8) DNS
// server as a caching only nameserver (as a localhost DNS resolver only).
// See /usr/share/doc/bind*/sample/ for example named configuration files.
// See the BIND Administrator's Reference Manual (ARM) for details about the
// configuration located in /usr/share/doc/bind-{version}/Bv9ARM.html
options {
listen-on port 53 { any; };
listen-on-v6 port 53 { any; };
directory "/var/named";
dump-file "/var/named/data/cache_dump.db";
statistics-file "/var/named/data/named_stats.txt";
memstatistics-file "/var/named/data/named_mem_stats.txt";
allow-query { any; };
allow-transfer { none; };
recursion no;
dnssec-enable yes;
dnssec-validation yes;
dnssec-lookaside no;
/* Path to ISC DLV key */
bindkeys-file "/etc/named.iscdlv.key";
managed-keys-directory "/var/named/dynamic";
logging {
channel default_debug {
file "data/named.run";
severity dynamic;
zone "." IN {
type hint;
file "named.ca";
include "/etc/named.rfc1912.zones";
include "/etc/named.root.key";
پرسیده شده در 1399/03/11 توسط
0 پاسخ
این سوال هنوز پاسخی ندارد
