50٪ تخفیف روی تمام دوره‌ها!
update . upgrade نشدن terminal kali
سلام وقتی من kalia updatenمی کنم  اینا میگه
 Ign:1 http://security.kali.org/kali-security kali/updates InRelease
Ign:2 http://repository.vscode.com stable InRelease
Ign:3 http://ftp.de.debian.org/debian lenny InRelease
Ign:4 http://http.kali.org /kali InRelease
Err:5 http://ftp.de.debian.org/debian lenny Release
  404  Not Found [IP: 141.76.2.4 80]
Ign:6 http://http.kali.org /wheezy InRelease
Ign:8 http://ftp.us.debian.org/debian wheezy InRelease
Ign:9 http://http.kali.org/kali kali InRelease
Err:10 http://ftp.us.debian.org/debian wheezy Release
  404  Not Found [IP: 208.80.154.139 80]
Err:7 http://kali.download/kali kali-dev InRelease
  403  Forbidden [IP: 104.17.254.239 80]
Err:11 http://kali.download/kali kali-experimental InRelease
Err:12 http://http.kali.org /kali Release
  404  Not Found [IP: 18.211.24.19 80]
Err:13 http://http.kali.org /wheezy Release
Err:14 http://http.kali.org/kali kali Release
Err:2 http://repository.vscode.com stable InRelease
  Could not resolve 'repository.vscode.com'
Err:1 http://security.kali.org/kali-security kali/updates InRelease
  Something wicked happened resolving 'security.kali.org:http' (-5 - No address associated with hostname)
Reading package lists... Done
N: See apt-secure(8) manpage for repository creation and user configuration details.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
E: The repository 'http://ftp.us.debian.org/debian wheezy Release' does not have a Release file.
E: The repository 'http://ftp.de.debian.org/debian lenny Release' does not have a Release file.
E: Failed to fetch http://http.kali.org/kali/dists/kali-dev/InRelease  403  Forbidden [IP: 104.17.254.239 80]
E: The repository 'http://http.kali.org/kali kali-dev InRelease' is not signed.
E: Failed to fetch http://http.kali.org/kali/dists/kali-experimental/InRelease  403  Forbidden [IP: 104.17.254.239 80]
E: The repository 'http://http.kali.org/kali kali-experimental InRelease' is not signed.
E: The repository 'http://http.kali.org /kali Release' does not have a Release file.
E: The repository 'http://http.kali.org /wheezy Release' does not have a Release file.
E: The repository 'http://http.kali.org/kali kali Release' does not have a Release file.
N: Repository 'Kali Linux' changed its 'firmware component' value from 'non-free' to 'non-free-firmware'
N: More information about this can be found online at: https://www.kali.org/blog/non-free-firmware-transition/
من الا برای این باید چیکار کنم؟
پرسیده شده در 1403/09/17 توسط
11 پاسخ
چه اروری؟
من خودم از همین شل اسکریپت استفده می کنم
پاسخ در 1403/09/17 توسط
این شل اسکریپت به صورت خودکار فایل sources.list رو اپدیت میکنه و از repository های mirror کالی استفاده میکنه. بعد از اجرا کردن میتونین بدون دردسر هر پکیجی که خواستین نصب و اپدیت کنین.
دستور زیر رو در ترمینال اجرا کنین:
git clone https://github.com/Sir-MmD/M-Switch.git && cd M-Switch && sudo bash m-switch.sh
اگه  ب ارور توجه کنین میگه که دایرکتوری M-switch وجود داره
 به دایرکتوری M-switch بعد دستور bash m-switch.sh اجرا کنین.
این کار هم میکنم باز ایدیت نمیشه میشه یه mirror list خوب بهم بدین لطفا
fatal: destination path 'M-Switch' already exists and is not an empty directory.
اینا میگه
بازم هرکاری می کنم نه ابدیت میشه نه ابگرید نه برنامه ای نصب میشه
