چگونه محیط گرافیکی را در لینوکس رد هت 6 بعد از نصب بالا بیاوریم؟
لینوکس رد هت 6 را در virtual box نصب کردم. بعد از نصب محیط command line بالا می یاد
1-چگونه می توانم محیط گرافیکی اش را بالا بیاورم؟
2- علی پیکربندی محیط ویژوال باکس برای دسترسی اینترنت اما در محیط کامند لاین به اینترنت دسترسی ندارم .
پرسیده شده در 1394/08/29 توسط
شما برای اینکه به محیط گرافیکی دست پیدا کنید باید ببینید redhat 6 در چه runLevel ی محیط گرافیکیش بالا میاد
RHEL Runlevels Descriptions
As previously outlined, RHEL 6 can be booted into one of a number of runlevels. The default runlevel to which the system is configured to boot will, in turn, dictate which services are started:
Runlevel 0 - The halt runlevel. This is the runlevel at which the system shuts down. For obvious reasons it is unlikely you would want this as your default runlevel.
Runlevel 1 – Causes the system to start up in a single user mode under which only the root user can log in. In this mode the system does not start any networking, X windowing or multi-user services. This run level is ideal for system administrators to perform system maintenance or repair activities.
Runlevel 2 - Boots the system into a multi-user mode with text based console login capability. This runlevel does not, however, start the network.
Runlevel 3 - Similar to runlevel 2 except that networking services are started. This is the most common runlevel for server based systems that do not require any kind of graphical desktop environment.
Runlevel 4 - Undefined runlevel. This runlevel can be configured to provide a custom boot state.
Runlevel 5 - Boots the system into a networked, multi-user state with X Window System capability. By default the graphical desktop environment will start at the end of the boot process. This is the most common run level for desktop or workstation use.
Runlevel 6 - Reboots the system. Another runlevel that, for obvious reasons, you are unlikely to want as your default.
که کلا 6 تا run level داریم و من فکر میکنم runlevel مد نظر شما 5 هست که grafic desktop داره
برای اینکه به ران لول 5 برید فکر میکنم باید دستور 5 init رو وارد کنید که البته باید با دسترسی root این دستور وارد بشه
پاسخ در 1394/08/30 توسط
