mikrotik load balancing
در مورد لودبالانسینگ روی میکروتیک توی توی ویکی میکروتیک کانفیگ کامل وجود داره
/ ip address
add address=192.168.0.1/24 network=192.168.0.0 broadcast=192.168.0.255 interface=LAN
add address=10.111.0.2/24 network=10.111.0.0 broadcast=10.111.0.255 interface=ISP1
add address=10.112.0.2/24 network=10.112.0.0 broadcast=10.112.0.255 interface=ISP2
/ ip firewall mangle
add chain=prerouting dst-address=10.111.0.0/24  action=accept in-interface=LAN
add chain=prerouting dst-address=10.112.0.0/24  action=accept in-interface=LAN
add chain=prerouting in-interface=ISP1 connection-mark=no-mark action=mark-connection     new-connection-mark=ISP1_conn
add chain=prerouting in-interface=ISP2 connection-mark=no-mark action=mark-connection \
    new-connection-mark=ISP2_conn
add chain=prerouting  in-interface=LAN connection-mark=no-mark dst-address-type=!local     per-connection-classifier=both-addresses:2/0 action=mark-connection new-connection-mark=ISP1_conn
add chain=prerouting  in-interface=LAN connection-mark=no-mark dst-address-type=!local \
    per-connection-classifier=both-addresses:2/1 action=mark-connection new-connection-mark=ISP2_conn
add chain=prerouting connection-mark=ISP1_conn in-interface=LAN action=mark-routing \
    new-routing-mark=to_ISP1
add chain=prerouting connection-mark=ISP2_conn in-interface=LAN action=mark-routing     new-routing-mark=to_ISP2
add chain=output connection-mark=ISP1_conn action=mark-routing new-routing-mark=to_ISP1
add chain=output connection-mark=ISP2_conn action=mark-routing new-routing-mark=to_ISP2
/ ip route
add dst-address=0.0.0.0/0 gateway=10.111.0.1 routing-mark=to_ISP1 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=10.112.0.1 routing-mark=to_ISP2 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=10.111.0.1 distance=1 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=10.112.0.1 distance=2 check-gateway=ping
/ ip firewall nat
add chain=srcnat out-interface=ISP1 action=masquerade
add chain=srcnat out-interface=ISP2 action=masquerade
ولی میخوام همین کانفیگ رو روی سه خط اینترنت انجام بدم و بین سه خط لودبالانس کنیم
لطفا اگه کسی از دوستان اطلاعات داره کمک کنه
پرسیده شده در 1394/12/17 توسط
بشخصه دنبال لود بالانس در میکروتیک زیاد گشتم, اما کمتر یافتم. حتی شنیدم لود بالانس در میکروتیک فول جواب نمیده.
امیدوارم دوستان دیگه بیان و کمک کنن.
به پی دی اف هست که میگه کانفیگش رو توضیح داده. من تست نکردم. امیدوارم مشکل گشا باشه.
Load Balancing using PCC connected via PPPoE
پاسخ در 1394/12/18 توسط
این کانفیک loadbalacing هست
به جای per-connection-classifier=both-addresses
این را قرار بده احتمالا زیاد حل میشه per-connection-classifier=src port
برای اضافه کردن FailOver هم باید چندتا Default Route اضافه بنویسی
پاسخ در 1395/10/04 توسط
با فرمایش شما حالا که چک میکنم ظاهرا FAIL OVER هست چون از سایت میکروتیک کپی کردم ولی در کل میخواستم بتونم بین بیش از دو لینک LOAD BALANCE کنم
هرچی میگردم همه نوشتن pcc لودبالانسینگ هست ولی کانفیگ توی سایت میکروتیک fail over هست
لطفا کمک کنید
ببخشید/ این Load balance ه یا Fail Over ؟
یعنی پکت ها رو تقسیم میکنه بین پورت ها یا فقط اگه پورتی داون شد میره رو بعدی؟
پاسخ در 1394/12/17 توسط
