مدارک ردهت یا lpic
سلام.
چرا مدرک ردهت از lpic معتبر تره ؟
افرادی مدرک مثلا lpic 1 میگیرن میتونن براحتی مدرک RHCSA بگیرن یا نه ربطی نداره کلا ؟
امتحان ردهت کدوم کشورها میگیرن ؟
به نظر شما وقت رو کدوم مدرک بزاریم بهتره ؟
پرسیده شده در 1395/05/29 توسط
آنچه برای آزمون RHCSA باید بدونید اینهاست
Understand and use essential tools#
Access a shell prompt and issue commands with correct syntax
Use input-output redirection (>, >>, |, 2>, etc.)
Use grep and regular expressions to analyze text
Access remote systems using ssh
Log in and switch users in multiuser targets
Archive, compress, unpack, and uncompress files using tar, star, gzip, and bzip2
Create and edit text files
Create, delete, copy, and move files and directories
Create hard and soft links
List, set, and change standard ugo/rwx permissions
Locate, read, and use system documentation including man, info, and files in usrshare/doc
Note: Red Hat may use applications during the exam that are not included in Red Hat Enterprise Linux for the purpose of evaluating candidate's abilities to meet this objective.
Operate running systems#
Boot, reboot, and shut down a system normally
Boot systems into different targets manually
Interrupt the boot process in order to gain access to a system
Identify CPU/memory intensive processes, adjust process priority with renice, and kill processes
Locate and interpret system log files and journals
Access a virtual machine's console
Start and stop virtual machines
Start, stop, and check the status of network services
Securely transfer files between systems
Configure local storage#
List, create, delete partitions on MBR and GPT disks
Create and remove physical volumes, assign physical volumes to volume groups, and create and delete logical volumes
Configure systems to mount file systems at boot by Universally Unique ID (UUID) or label
Add new partitions and logical volumes, and swap to a system non-destructively
Create and configure file systems#
Create, mount, unmount, and use vfat, ext4, and xfs file systems
Mount and unmount CIFS and NFS network file systems
Extend existing logical volumes
Create and configure set-GID directories for collaboration
Create and manage Access Control Lists (ACLs)
Diagnose and correct file permission problems
Deploy, configure, and maintain systems#
Configure networking and hostname resolution statically or dynamically
Schedule tasks using at and cron
Start and stop services and configure services to start automatically at boot
Configure systems to boot into a specific target automatically
Install Red Hat Enterprise Linux automatically using Kickstart
Configure a physical machine to host virtual guests
Install Red Hat Enterprise Linux systems as virtual guests
Configure systems to launch virtual machines at boot
Configure network services to start automatically at boot
Configure a system to use time services
Install and update software packages from Red Hat Network, a remote repository, or from the local file system
Update the kernel package appropriately to ensure a bootable system
Modify the system bootloader
Manage users and groups#
Create, delete, and modify local user accounts
Change passwords and adjust password aging for local user accounts
Create, delete, and modify local groups and group memberships
Configure a system to use an existing authentication service for user and group information
Manage security#
Configure firewall settings using firewall-config, firewall-cmd, or iptables
Configure key-based authentication for SSH
Set enforcing and permissive modes for SELinux
List and identify SELinux file and process context
Restore default file contexts
Use boolean settings to modify system SELinux settings
Diagnose and address routine SELinux policy violations
پاسخ در 1396/02/15 توسط
به جرات میشه گفت ردهت اولین شرکتی بود که به صورت حرفه ای رو لینوکس سرمایه گذاری کرد و پشتیبانی بی نظیری داره و در ضمن امریکاییه!
lpi روی توزیع خاصی تمرکز نداره جامع تره بر خلاف ردهت که روی توزیع خودش تمرکز داره اما امتحانات ردهت سختره و با وسواس خاصی گرفته میشه
به نظر من باید این تفکر مدرک گرایی و کنکوری که توی همه ماها نهادینده شده رو کنار گذاشت شما فقط یاد بگیر تا اونجایی که میتونی بخون و در چارچوب خاصی خودتو محدود نکن و اینو باید بدونیم همه کسایی که گیک هستن و غول های لینوکس مدرکی ندارند،لینوکس در دنیای واقعی به میزان زیادی خلاقیت و همت میخواد
پاسخ در 1395/05/29 توسط
