تداخل فایل در php
سلام.
بعد از اجرای دستور:
yum install php70w-mbstring
خطای زیر رو دارم:
Transaction Check Error:
  file /etc/php.ini from install of php70w-common-7.0.20-1.w6.x86_64 conflicts with file from package php-common-7.0.21-1.el6.remi.x86_64
  file /usr/lib64/php-zts/modules/bz2.so from install of php70w-common-7.0.20-1.w6.x86_64 conflicts with file from package php-common-7.0.21-1.el6.remi.x86_64
  file /usr/lib64/php/modules/bz2.so from install of php70w-common-7.0.20-1.w6.x86_64 conflicts with file from package php-common-7.0.21-1.el6.remi.x86_64
  file /usr/lib64/php-zts/modules/calendar.so from install of php70w-common-7.0.20-1.w6.x86_64 conflicts with file from package php-common-7.0.21-1.el6.remi.x86_64
  file /usr/lib64/php/modules/calendar.so from install of php70w-common-7.0.20-1.w6.x86_64 conflicts with file from package php-common-7.0.21-1.el6.remi.x86_64
  file /usr/lib64/php-zts/modules/ctype.so from install of php70w-common-7.0.20-1.w6.x86_64 conflicts with file from package php-common-7.0.21-1.el6.remi.x86_64
  file /usr/lib64/php/modules/ctype.so from install of php70w-common-7.0.20-1.w6.x86_64 conflicts with file from package php-common-7.0.21-1.el6.remi.x86_64
  file /usr/lib64/php-zts/modules/curl.so from install of php70w-common-7.0.20-1.w6.x86_64 conflicts with file from package php-common-7.0.21-1.el6.remi.x86_64
  file /usr/lib64/php/modules/curl.so from install of php70w-common-7.0.20-1.w6.x86_64 conflicts with file from package php-common-7.0.21-1.el6.remi.x86_64
  file /usr/lib64/php-zts/modules/exif.so from install of php70w-common-7.0.20-1.w6.x86_64 conflicts with file from package php-common-7.0.21-1.el6.remi.x86_64
  file /usr/lib64/php/modules/exif.so from install of php70w-common-7.0.20-1.w6.x86_64 conflicts with file from package php-common-7.0.21-1.el6.remi.x86_64
  file /usr/lib64/php-zts/modules/fileinfo.so from install of php70w-common-7.0.20-1.w6.x86_64 conflicts with file from package php-common-7.0.21-1.el6.remi.x86_64
  file /usr/lib64/php/modules/fileinfo.so from install of php70w-common-7.0.20-1.w6.x86_64 conflicts with file from package php-common-7.0.21-1.el6.remi.x86_64
  file /usr/lib64/php-zts/modules/ftp.so from install of php70w-common-7.0.20-1.w6.x86_64 conflicts with file from package php-common-7.0.21-1.el6.remi.x86_64
  file /usr/lib64/php/modules/ftp.so from install of php70w-common-7.0.20-1.w6.x86_64 conflicts with file from package php-common-7.0.21-1.el6.remi.x86_64
  file /usr/lib64/php-zts/modules/gettext.so from install of php70w-common-7.0.20-1.w6.x86_64 conflicts with file from package php-common-7.0.21-1.el6.remi.x86_64
  file /usr/lib64/php/modules/gettext.so from install of php70w-common-7.0.20-1.w6.x86_64 conflicts with file from package php-common-7.0.21-1.el6.remi.x86_64
  file /usr/lib64/php-zts/modules/iconv.so from install of php70w-common-7.0.20-1.w6.x86_64 conflicts with file from package php-common-7.0.21-1.el6.remi.x86_64
  file /usr/lib64/php/modules/iconv.so from install of php70w-common-7.0.20-1.w6.x86_64 conflicts with file from package php-common-7.0.21-1.el6.remi.x86_64
  file /usr/lib64/php-zts/modules/phar.so from install of php70w-common-7.0.20-1.w6.x86_64 conflicts with file from package php-common-7.0.21-1.el6.remi.x86_64
  file /usr/lib64/php/modules/phar.so from install of php70w-common-7.0.20-1.w6.x86_64 conflicts with file from package php-common-7.0.21-1.el6.remi.x86_64
  file /usr/lib64/php-zts/modules/sockets.so from install of php70w-common-7.0.20-1.w6.x86_64 conflicts with file from package php-common-7.0.21-1.el6.remi.x86_64
  file /usr/lib64/php/modules/sockets.so from install of php70w-common-7.0.20-1.w6.x86_64 conflicts with file from package php-common-7.0.21-1.el6.remi.x86_64
  file /usr/lib64/php-zts/modules/tokenizer.so from install of php70w-common-7.0.20-1.w6.x86_64 conflicts with file from package php-common-7.0.21-1.el6.remi.x86_64
  file /usr/lib64/php/modules/tokenizer.so from install of php70w-common-7.0.20-1.w6.x86_64 conflicts with file from package php-common-7.0.21-1.el6.remi.x86_64
  file /usr/lib64/php-zts/modules/json.so from install of php70w-common-7.0.20-1.w6.x86_64 conflicts with file from package php-json-7.0.21-1.el6.remi.x86_64
  file /usr/lib64/php/modules/json.so from install of php70w-common-7.0.20-1.w6.x86_64 conflicts with file from package php-json-7.0.21-1.el6.remi.x86_64
  file /usr/lib64/php-zts/modules/simplexml.so from install of php70w-common-7.0.20-1.w6.x86_64 conflicts with file from package php-xml-7.0.21-1.el6.remi.x86_64
  file /usr/lib64/php/modules/simplexml.so from install of php70w-common-7.0.20-1.w6.x86_64 conflicts with file from package php-xml-7.0.21-1.el6.remi.x86_64
  file /usr/lib64/php-zts/modules/xml.so from install of php70w-common-7.0.20-1.w6.x86_64 conflicts with file from package php-xml-7.0.21-1.el6.remi.x86_64
  file /usr/lib64/php/modules/xml.so from install of php70w-common-7.0.20-1.w6.x86_64 conflicts with file from package php-xml-7.0.21-1.el6.remi.x86_64
  file /usr/lib64/php-zts/modules/gmp.so from install of php70w-common-7.0.20-1.w6.x86_64 conflicts with file from package php-gmp-7.0.21-1.el6.remi.x86_64
  file /usr/lib64/php/modules/gmp.so from install of php70w-common-7.0.20-1.w6.x86_64 conflicts with file from package php-gmp-7.0.21-1.el6.remi.x86_64
  file /usr/lib64/php-zts/modules/mbstring.so from install of php70w-mbstring-7.0.20-1.w6.x86_64 conflicts with file from package php-mbstring-7.0.21-1.el6.remi.x86_64
  file /usr/lib64/php/modules/mbstring.so from install of php70w-mbstring-7.0.20-1.w6.x86_64 conflicts with file from package php-mbstring-7.0.21-1.el6.remi.x86_64
  file /usr/lib64/php-zts/modules/shmop.so from install of php70w-common-7.0.20-1.w6.x86_64 conflicts with file from package php-process-7.0.21-1.el6.remi.x86_64
  file /usr/lib64/php/modules/shmop.so from install of php70w-common-7.0.20-1.w6.x86_64 conflicts with file from package php-process-7.0.21-1.el6.remi.x86_64
  file /usr/lib64/php-zts/modules/zip.so from install of php70w-common-7.0.20-1.w6.x86_64 conflicts with file from package php-pecl-zip-1.15.0-1.el6.remi.7.0.x86_64
  file /usr/lib64/php/modules/zip.so from install of php70w-common-7.0.20-1.w6.x86_64 conflicts with file from package php-pecl-zip-1.15.0-1.el6.remi.7.0.x86_64
Error Summary
و خروجی از ورژن php بصورت زیر هست:
[root@srv ~]# php -v
PHP 7.0.21 (cli) (built: Jul  5 2017 15:43:03) ( NTS )
Copyright (c) 1997-2017 The PHP Group
Zend Engine v3.0.0, Copyright (c) 1998-2017 Zend Technologies
    with Zend OPcache v7.0.21, Copyright (c) 1999-2017, by Zend Technologies
چطور میتونم اون تداخل رو برطرف کنم؟
پرسیده شده در 1396/04/20 توسط
0 پاسخ
این سوال هنوز پاسخی ندارد
