ارور در نصب درایور کارت شبکه tp-link tl-wn821n در لینوکس اوبونتو
با سلام و سخته نباشید.بنده در نصب درایور (دانلود شده از سایت اصلی کارت شبکه) کارت شبکه tp-link tl-wn821n در لینوکس اوبونتو با این ارور مواجه شدم.آیا کسی میدونه مشکل چیه؟
متن ارور در ترمینال:
deadhopes@ubuntu:~DesktopTL-WN821NV5160315_Linux/Driver$ make
"NO SKRC,we will use default KSRC"
make ARCH=i386 CROSSCOMPILE= -C libmodules4.10.0-32-genericbuild M=homedeadhopesDesktopTL-WN821NV5160315Linux/Driver modules
make[1]: Entering directory 'usrsrc/linux-headers-4.10.0-32-generic'
CC [M] homedeadhopesDesktopTL-WN821NV5160315LinuxDrivercore/rtwcmd.o
In file included from homedeadhopesDesktopTL-WN821NV5160315LinuxDriverinclude/drvtypes.h:95:0,
from homedeadhopesDesktopTL-WN821NV5160315LinuxDrivercore/rtwcmd.c:22:
homedeadhopesDesktopTL-WN821NV5160315LinuxDriverinclude/halcom.h:413:13: error: ‘file_path’ redeclared as different kind of symbol
extern char filepath[PATHLENGTH_MAX];
In file included from .includelinux/seq_file.h:10:0,
from .includelinuxpinctrlconsumer.h:17,
from .includelinuxpinctrldevinfo.h:21,
from .includelinux/device.h:24,
from .includelinux/dmaengine.h:20,
from .includelinux/netdevice.h:38,
from homedeadhopesDesktopTL-WN821NV5160315LinuxDriverinclude/osdepservice_linux.h:35,
from homedeadhopesDesktopTL-WN821NV5160315LinuxDriverinclude/osdepservice.h:41,
from homedeadhopesDesktopTL-WN821NV5160315LinuxDriverinclude/drvtypes.h:32,
.includelinux/fs.h:2680:14: note: previous declaration of ‘file_path’ was here
extern char file_path(struct file , char *, int);
In file included from homedeadhopesDesktopTL-WN821NV5160315LinuxDriverinclude/drvtypes.h:65:0,
homedeadhopesDesktopTL-WN821NV5160315LinuxDrivercore/rtwcmd.c: In function ‘btinfoevtdump’:
homedeadhopesDesktopTL-WN821NV5160315LinuxDriverinclude/rtwdebug.h:187:19: error: void value not ignored as it ought to be
#define seqdump seqprintf
homedeadhopesDesktopTL-WN821NV5160315LinuxDriverinclude/rtwdebug.h:242:7: note: in expansion of macro ‘_seqdump’
if(seqdump(sel, fmt, ##arg)) /*rtwwarn_on(1)*/; \
homedeadhopesDesktopTL-WN821NV5160315LinuxDrivercore/rtwcmd.c:3293:2: note: in expansion of macro ‘DBG871XSEL_NL’
DBG871XSEL_NL(sel, "cid:0x%02x, len:%u\n", info->cid, info->len);
homedeadhopesDesktopTL-WN821NV5160315LinuxDrivercore/rtwcmd.c:3296:3: note: in expansion of macro ‘DBG871XSEL_NL’
DBG871XSEL_NL(sel, "byte2:%s%s%s%s%s%s%s%s\n"
homedeadhopesDesktopTL-WN821NV5160315LinuxDrivercore/rtwcmd.c:3308:3: note: in expansion of macro ‘DBG871XSEL_NL’
DBG871XSELNL(sel, "retrycnt:%u\n", info->retry_cnt);
homedeadhopesDesktopTL-WN821NV5160315LinuxDrivercore/rtwcmd.c:3311:3: note: in expansion of macro ‘DBG871XSEL_NL’
DBG871XSEL_NL(sel, "rssi:%u\n", info->rssi);
homedeadhopesDesktopTL-WN821NV5160315LinuxDrivercore/rtwcmd.c:3314:3: note: in expansion of macro ‘DBG871XSEL_NL’
DBG871XSEL_NL(sel, "byte5:%s%s\n"
scriptsMakefile.build:294: recipe for target 'homedeadhopesDesktopTL-WN821NV5160315_LinuxDrivercorertw_cmd.o' failed
make[2]: *** [homedeadhopesDesktopTL-WN821NV5160315LinuxDrivercore/rtwcmd.o] Error 1
Makefile:1524: recipe for target 'modulehomedeadhopesDesktopTL-WN821NV5160315_Linux/Driver' failed
make[1]: *** [modulehomedeadhopesDesktopTL-WN821NV5160315_Linux/Driver] Error 2
make[1]: Leaving directory 'usrsrc/linux-headers-4.10.0-32-generic'
Makefile:1696: recipe for target 'modules' failed
make: *** [modules] Error 2
پرسیده شده در 1396/05/25 توسط
دوست عزیز دقت کنید Chipset کارت شبکه چیه ، بعد برین به دنبال نصب درایور اون Chipset.
من خودم مشکلی شبیه به شما داشتم و از سایت اصلی TP-Link درایور رو دانلود کردم اما نصب نمیشد ، بعد فهمیدم کارتی که من داشتم نسخه 2 بود و Chipsetـش با نسخه 1 متفاوت بود.
موفق باشید.
پاسخ در 1396/07/14 توسط
