مشکل با vmmon
باسلام
من روی لینوکس هر توزیعی نصب کردم با vmware همین مشکل و دارم
فایل لاگ رو براتون پیوست میکنم
لطفا یکی مشکل منو حل کنه توی نت چند تا راه بود انجام دادم درست نشد
پیشاپیش تشکر
2018-06-14T00:29:59.775+04:30| vthread-1| I125: Log for VMware Workstation pid=7946 version=14.0.0 build=build-6661328 option=Release 2018-06-14T00:29:59.775+04:30| vthread-1| I125: The process is 64-bit. 2018-06-14T00:29:59.775+04:30| vthread-1| I125: Host codepage=UTF-8 encoding=UTF-8 2018-06-14T00:29:59.775+04:30| vthread-1| I125: Host is Linux 4.15.0-23-generic Ubuntu 18.04 LTS 2018-06-14T00:29:59.774+04:30| vthread-1| I125: DictionaryLoad: Cannot open file "/usr/lib/vmware/settings": No such file or directory. 2018-06-14T00:29:59.774+04:30| vthread-1| I125: [msg.dictionary.load.openFailed] Cannot open file "/usr/lib/vmware/settings": No such file or directory. 2018-06-14T00:29:59.774+04:30| vthread-1| I125: PREF Optional preferences file not found at /usr/lib/vmware/settings. Using default values. 2018-06-14T00:29:59.774+04:30| vthread-1| I125: DictionaryLoad: Cannot open file "/home/mohammad/.vmware/config": No such file or directory. 2018-06-14T00:29:59.774+04:30| vthread-1| I125: [msg.dictionary.load.openFailed] Cannot open file "/home/mohammad/.vmware/config": No such file or directory. 2018-06-14T00:29:59.774+04:30| vthread-1| I125: PREF Optional preferences file not found at /home/mohammad/.vmware/config. Using default values. 2018-06-14T00:29:59.774+04:30| vthread-1| I125: DictionaryLoad: Cannot open file "/home/mohammad/.vmware/preferences": No such file or directory. 2018-06-14T00:29:59.774+04:30| vthread-1| I125: [msg.dictionary.load.openFailed] Cannot open file "/home/mohammad/.vmware/preferences": No such file or directory. 2018-06-14T00:29:59.774+04:30| vthread-1| I125: PREF Optional preferences file not found at /home/mohammad/.vmware/preferences. Using default values. 2018-06-14T00:29:59.820+04:30| vthread-1| W115: Logging to /tmp/vmware-root/vmware-7946.log 2018-06-14T00:29:59.829+04:30| vthread-1| I125: Obtaining info using the running kernel. 2018-06-14T00:29:59.829+04:30| vthread-1| I125: Created new pathsHash. 2018-06-14T00:29:59.829+04:30| vthread-1| I125: Setting header path for 4.15.0-23-generic to "/lib/modules/4.15.0-23-generic/build/include". 2018-06-14T00:29:59.829+04:30| vthread-1| I125: Validating path "/lib/modules/4.15.0-23-generic/build/include" for kernel release "4.15.0-23-generic". 2018-06-14T00:29:59.829+04:30| vthread-1| I125: Failed to find /lib/modules/4.15.0-23-generic/build/include/linux/version.h 2018-06-14T00:29:59.829+04:30| vthread-1| I125: /lib/modules/4.15.0-23-generic/build/include/linux/version.h not found, looking for generated/uapi/linux/version.h instead. 2018-06-14T00:29:59.829+04:30| vthread-1| I125: using /usr/bin/gcc-7 for preprocess check 2018-06-14T00:29:59.834+04:30| vthread-1| I125: Preprocessed UTS_RELEASE, got value "4.15.0-23-generic". 2018-06-14T00:29:59.834+04:30| vthread-1| I125: The header path "/lib/modules/4.15.0-23-generic/build/include" for the kernel "4.15.0-23-generic" is valid. Whoohoo! 2018-06-14T00:29:59.998+04:30| vthread-1| I125: found symbol version file /lib/modules/4.15.0-23-generic/build/Module.symvers 2018-06-14T00:29:59.998+04:30| vthread-1| I125: Reading symbol versions from /lib/modules/4.15.0-23-generic/build/Module.symvers. 2018-06-14T00:30:00.018+04:30| vthread-1| I125: Read 22722 symbol versions 2018-06-14T00:30:00.019+04:30| vthread-1| I125: Reading in info for the vmmon module. 2018-06-14T00:30:00.019+04:30| vthread-1| I125: Reading in info for the vmnet module. 2018-06-14T00:30:00.019+04:30| vthread-1| I125: Reading in info for the vmblock module. 2018-06-14T00:30:00.019+04:30| vthread-1| I125: Reading in info for the vmci module. 2018-06-14T00:30:00.019+04:30| vthread-1| I125: Reading in info for the vsock module. 2018-06-14T00:30:00.019+04:30| vthread-1| I125: Setting vsock to depend on vmci. 2018-06-14T00:30:00.019+04:30| vthread-1| I125: Invoking modinfo on "vmmon". 2018-06-14T00:30:00.020+04:30| vthread-1| I125: "/sbin/modinfo" exited with status 256. 2018-06-14T00:30:00.020+04:30| vthread-1| I125: Invoking modinfo on "vmnet". 2018-06-14T00:30:00.022+04:30| vthread-1| I125: "/sbin/modinfo" exited with status 0. 2018-06-14T00:30:00.022+04:30| vthread-1| I125: Invoking modinfo on "vmblock". 2018-06-14T00:30:00.023+04:30| vthread-1| I125: "/sbin/modinfo" exited with status 256. 2018-06-14T00:30:00.023+04:30| vthread-1| I125: Invoking modinfo on "vmci". 2018-06-14T00:30:00.025+04:30| vthread-1| I125: "/sbin/modinfo" exited with status 256. 2018-06-14T00:30:00.025+04:30| vthread-1| I125: Invoking modinfo on "vsock". 2018-06-14T00:30:00.027+04:30| vthread-1| I125: "/sbin/modinfo" exited with status 0. 2018-06-14T00:30:00.041+04:30| vthread-1| I125: to be installed: vmmon status: 0 2018-06-14T00:30:00.052+04:30| vthread-1| I125: Obtaining info using the running kernel. 2018-06-14T00:30:00.052+04:30| vthread-1| I125: Setting header path for 4.15.0-23-generic to "/lib/modules/4.15.0-23-generic/build/include". 2018-06-14T00:30:00.052+04:30| vthread-1| I125: Validating path "/lib/modules/4.15.0-23-generic/build/include" for kernel release "4.15.0-23-generic". 2018-06-14T00:30:00.052+04:30| vthread-1| I125: Failed to find /lib/modules/4.15.0-23-generic/build/include/linux/version.h 2018-06-14T00:30:00.052+04:30| vthread-1| I125: /lib/modules/4.15.0-23-generic/build/include/linux/version.h not found, looking for generated/uapi/linux/version.h instead. 2018-06-14T00:30:00.052+04:30| vthread-1| I125: using /usr/bin/gcc-7 for preprocess check 2018-06-14T00:30:00.057+04:30| vthread-1| I125: Preprocessed UTS_RELEASE, got value "4.15.0-23-generic". 2018-06-14T00:30:00.057+04:30| vthread-1| I125: The header path "/lib/modules/4.15.0-23-generic/build/include" for the kernel "4.15.0-23-generic" is valid. Whoohoo! 2018-06-14T00:30:00.216+04:30| vthread-1| I125: found symbol version file /lib/modules/4.15.0-23-generic/build/Module.symvers 2018-06-14T00:30:00.216+04:30| vthread-1| I125: Reading symbol versions from /lib/modules/4.15.0-23-generic/build/Module.symvers. 2018-06-14T00:30:00.234+04:30| vthread-1| I125: Read 22722 symbol versions 2018-06-14T00:30:00.235+04:30| vthread-1| I125: Kernel header path retrieved from FileEntry: /lib/modules/4.15.0-23-generic/build/include 2018-06-14T00:30:00.235+04:30| vthread-1| I125: Update kernel header path to /lib/modules/4.15.0-23-generic/build/include 2018-06-14T00:30:00.235+04:30| vthread-1| I125: Validating path "/lib/modules/4.15.0-23-generic/build/include" for kernel release "4.15.0-23-generic". 2018-06-14T00:30:00.235+04:30| vthread-1| I125: Failed to find /lib/modules/4.15.0-23-generic/build/include/linux/version.h 2018-06-14T00:30:00.235+04:30| vthread-1| I125: /lib/modules/4.15.0-23-generic/build/include/linux/version.h not found, looking for generated/uapi/linux/version.h instead. 2018-06-14T00:30:00.235+04:30| vthread-1| I125: using /usr/bin/gcc-7 for preprocess check 2018-06-14T00:30:00.240+04:30| vthread-1| I125: Preprocessed UTS_RELEASE, got value "4.15.0-23-generic". 2018-06-14T00:30:00.240+04:30| vthread-1| I125: The header path "/lib/modules/4.15.0-23-generic/build/include" for the kernel "4.15.0-23-generic" is valid. Whoohoo! 2018-06-14T00:30:00.241+04:30| vthread-1| I125: Found compiler at "/usr/bin/gcc" 2018-06-14T00:30:00.244+04:30| vthread-1| I125: Got gcc version "7". 2018-06-14T00:30:00.244+04:30| vthread-1| I125: The GCC version matches the kernel GCC minor version like a glove. 2018-06-14T00:30:00.246+04:30| vthread-1| I125: Got gcc version "7". 2018-06-14T00:30:00.246+04:30| vthread-1| I125: The GCC version matches the kernel GCC minor version like a glove. 2018-06-14T00:30:00.247+04:30| vthread-1| I125: Trying to find a suitable PBM set for kernel "4.15.0-23-generic". 2018-06-14T00:30:00.248+04:30| vthread-1| I125: No matching PBM set was found for kernel "4.15.0-23-generic". 2018-06-14T00:30:00.248+04:30| vthread-1| I125: The GCC version matches the kernel GCC minor version like a glove. 2018-06-14T00:30:00.248+04:30| vthread-1| I125: Validating path "/lib/modules/4.15.0-23-generic/build/include" for kernel release "4.15.0-23-generic". 2018-06-14T00:30:00.248+04:30| vthread-1| I125: Failed to find /lib/modules/4.15.0-23-generic/build/include/linux/version.h 2018-06-14T00:30:00.248+04:30| vthread-1| I125: /lib/modules/4.15.0-23-generic/build/include/linux/version.h not found, looking for generated/uapi/linux/version.h instead. 2018-06-14T00:30:00.248+04:30| vthread-1| I125: using /usr/bin/gcc-7 for preprocess check 2018-06-14T00:30:00.255+04:30| vthread-1| I125: Preprocessed UTS_RELEASE, got value "4.15.0-23-generic". 2018-06-14T00:30:00.255+04:30| vthread-1| I125: The header path "/lib/modules/4.15.0-23-generic/build/include" for the kernel "4.15.0-23-generic" is valid. Whoohoo! 2018-06-14T00:30:00.257+04:30| vthread-1| I125: The GCC version matches the kernel GCC minor version like a glove. 2018-06-14T00:30:00.257+04:30| vthread-1| I125: Validating path "/lib/modules/4.15.0-23-generic/build/include" for kernel release "4.15.0-23-generic". 2018-06-14T00:30:00.257+04:30| vthread-1| I125: Failed to find /lib/modules/4.15.0-23-generic/build/include/linux/version.h 2018-06-14T00:30:00.257+04:30| vthread-1| I125: /lib/modules/4.15.0-23-generic/build/include/linux/version.h not found, looking for generated/uapi/linux/version.h instead. 2018-06-14T00:30:00.257+04:30| vthread-1| I125: using /usr/bin/gcc-7 for preprocess check 2018-06-14T00:30:00.265+04:30| vthread-1| I125: Preprocessed UTS_RELEASE, got value "4.15.0-23-generic". 2018-06-14T00:30:00.265+04:30| vthread-1| I125: The header path "/lib/modules/4.15.0-23-generic/build/include" for the kernel "4.15.0-23-generic" is valid. Whoohoo! 2018-06-14T00:30:00.265+04:30| vthread-1| I125: Using temp dir "/tmp". 2018-06-14T00:30:00.267+04:30| vthread-1| I125: Obtaining info using the running kernel. 2018-06-14T00:30:00.267+04:30| vthread-1| I125: Setting header path for 4.15.0-23-generic to "/lib/modules/4.15.0-23-generic/build/include". 2018-06-14T00:30:00.267+04:30| vthread-1| I125: Validating path "/lib/modules/4.15.0-23-generic/build/include" for kernel release "4.15.0-23-generic". 2018-06-14T00:30:00.267+04:30| vthread-1| I125: Failed to find /lib/modules/4.15.0-23-generic/build/include/linux/version.h 2018-06-14T00:30:00.267+04:30| vthread-1| I125: /lib/modules/4.15.0-23-generic/build/include/linux/version.h not found, looking for generated/uapi/linux/version.h instead. 2018-06-14T00:30:00.267+04:30| vthread-1| I125: using /usr/bin/gcc-7 for preprocess check 2018-06-14T00:30:00.276+04:30| vthread-1| I125: Preprocessed UTS_RELEASE, got value "4.15.0-23-generic". 2018-06-14T00:30:00.276+04:30| vthread-1| I125: The header path "/lib/modules/4.15.0-23-generic/build/include" for the kernel "4.15.0-23-generic" is valid. Whoohoo! 2018-06-14T00:30:00.441+04:30| vthread-1| I125: found symbol version file /lib/modules/4.15.0-23-generic/build/Module.symvers 2018-06-14T00:30:00.441+04:30| vthread-1| I125: Reading symbol versions from /lib/modules/4.15.0-23-generic/build/Module.symvers. 2018-06-14T00:30:00.459+04:30| vthread-1| I125: Read 22722 symbol versions 2018-06-14T00:30:00.459+04:30| vthread-1| I125: Invoking modinfo on "vmmon". 2018-06-14T00:30:00.461+04:30| vthread-1| I125: "/sbin/modinfo" exited with status 256. 2018-06-14T00:30:01.107+04:30| vthread-1| I125: Setting destination path for vmmon to "/lib/modules/4.15.0-23-generic/misc/vmmon.ko". 2018-06-14T00:30:01.107+04:30| vthread-1| I125: Extracting the vmmon source from "/usr/lib/vmware/modules/source/vmmon.tar". 2018-06-14T00:30:01.115+04:30| vthread-1| I125: Successfully extracted the vmmon source. 2018-06-14T00:30:01.115+04:30| vthread-1| I125: Building module with command "/usr/bin/make -j4 -C /tmp/modconfig-Hl6ZiQ/vmmon-only auto-build HEADER_DIR=/lib/modules/4.15.0-23-generic/build/include CC=/usr/bin/gcc IS_GCC_3=no" 2018-06-14T00:30:02.822+04:30| vthread-1| W115: Failed to build vmmon. Failed to execute the build command.
سلام و درود...
من هم به تازگی با مشکلی که دوستمون برخورد کرده بودند(اگرچه خیلی وقت پیش!) مواجه شدم و خوشبختانه تونستم مشکل رو رفعش کنم.
مشکل من بعد از upgrade کردن بسته های سیستم پیش اومد و بعد از اجرای vmware به ارور زیر برخورد کردم!
بعد از انتخاب گزینه Install ماژول های vmmon و vmnet که برای اجرای vmware ضروری هستند رو به عنوان ماژول هایی که نیاز به build شدن داشتند و مشکل دارند بهم معرفی کرد.(با مراجعه به آدرس لاگی که موقع ارور برگردونده شد.) همونطوری که تو خط آخر فایل لاگی که این دوستمون قرار دادن مشخصه که با مشکل مواجه هستش:
روش حل:
تنها روشی که منطقی به نظر میومد که مشکل رو برطرف کنه این بود ماژول ها رو جداگونه از جایی دانلود کنم و بعدش هم کامپایل تا مشکل رفع شه. من برای دانلود سورس ماژول ها طبق ورژن vmware از این لینک استفاده کردم:
https://github.com/mkubecek/vmware-host-modules/releases
بعد از حالت فشرده خارج کردن فایل دانلود شده با رفتن به آدرس پوشه ایجاد شده درون ترمینال و با استفاده از دستورات زیر ماژول ها رو کامپایل کردم:
sudo make
sudo make install
البته علاوه بر سورس ماژول ها فایل راهنما نحوه build کردن تو حالت های مختلف هم توی پوشه موجود بود!
در نهایت هم سرویس vmware رو مجدد راه اندازی کردم:
sudo /etc/init.d/vmware restart
بعدش همه ماژول ها به درستی لود شده و برنامه vmware اجرا شد.
و همه چیز به خوبی و خوشی قبل برگشت... :)
امیدوارم در آینده حداقل بتونه به فرد دیگه ای کمک کنه. :)
دقیقا چه موقعی این ارور رو دریافت می کنید ؟ و اینکه ارور رو کجا دریافت می کنید ؟
توی سیستم عامل قبلی
زمانی ک میخواستم سیستم عاملی روی اجرا کنم این ارور میداد
اما توی این توزیع اوبونتو زمانی ک خود vmware رو اجرا میکنم این ارور رو میده
چشم تست میکنم خبر میدم
ببینید شما روی لینوکسی که خودش روی VMware نصب شده اومدین VMware رو داخلش نصب کردید درسته ؟
منظورتون از اینکه VMware رو اجرا می کنید و این ارور میاد چیه ؟
میشه یه عکس از ارور بفرستید ؟
لینک زیر رو ببینید :
https://askubuntu.com/questions/812552/vmware-workstation-pro-12-on-ubuntu-16-04-cannot-compile-vmmon
